- perfect 1080p fullhd video streaming
- multiuser support
- usb webcam support
- autohide status bar
- multi usb partitions support
- busybox up to date
- google apps up to date
- hardware keyboard support
- lock screen support
- google searchbar is disable by default
- screen rotation support
- enable tun in the kernel
- notifacation sound support
- reboot/sleep/bootloader mode dialog
- init.d support
- ir-remote, A2 Airmouse support
- cwm recovery support
- ntfs, nfs, cifs filesystem support
- rooted
Link download: wasser-firmware-kikat-um2-1.0.1.zip
please use RKBatchTool to flash the new firmware
version 0.95
- kikat 4.4.2
- sound device manager
- wifi support
- ethernet support
- bluetooth support
- ir-remote support (it works with minix stock ir-remote, i don't have um2 stock ir-remote!)
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager
- remove google searchbar
- cwm recovery
- add screen rotation
- add notification sound
- add lock screen
- update busybox
- update google apps
- add hardware keyboard
- added 1080p24hz, 1080p30hz
Link download: wasser-firmware-kikat-ugoos-um2-0.95.zip
