Ugoos UM2 - wasser firmware - Kikat Android 4.4.2
Originally posted by jacksegundo View PostYou may want to have a look at this thread:
http://www.freaktab.com/showthread.p...Firmware-ToolsI used the kernel of the 1.01 UM2 version from Wasser.
This is for me the perfect combination, all is working now.
Originally posted by jacksegundo View PostGreat to know it's working for you now. But don't thank me, thank wasser for his fantasic ROM's.
You are absolutely right, Shame on ME.
Wasser i hope you read this.
You have made me an very happy Ugoos UM2 owner by making your Amazing firmware's.
I hope that many owners of this kind of sticks can use the findings, so they also be very happy when viewing movies or listen to Music
So a Big Thank you from me to you Wasser
Hi.
ik cant seems to connect my UM2 to my windows 7 pc.
how do you do it?
Connecting with only the micro USB to usb doenst work.
Connecting with both micro and normal USB to USB doesnt work
Connecting with micro USB to power and normal USB to USB doenst work.
i never once get the ba-boom (connected sound), when i connect my s5 to the same cable it immidiatly gets connected.
USB debugging is on, i dont know what to do anymore.
This device is useless to me when WiFi is working so bad (just 50KB/s while my S5 gets 80MB/s at the same distance), i wanted it to stream netflix and youtube.
Originally posted by madmaus View Postik cant seems to connect my UM2 to my windows 7 pc.
how do you do it?
Press & hold the reset button while plugging the USB in.
(Reset button is the little hole, so use a needle or something)
Use RKBatchTool for flashing firmware.
Good luck!
Help
Originally posted by Huff View PostNice to here, But where did you find the kernel of that image ?
I can only find the complete rom image of the Allminipc firmware.
Would you be so kind as to share it on mega for me so i can flash?
Steven
Originally posted by shenery View PostHi, ive tried everything to get firmware tools to build your kernel and rom combination for the um2. I think there is a problem with my windows xp.
Steven
H Steven,
Here is the Kernel I used.
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
Huff
can you flash that kernel through cwm?
Originally posted by shenery View Postthanks but i dont know how to compile it on to the minix firmware. my flash tools doesnt work for that for some reason.
Only select kernel, browse to the kernel.img file, make sure the UM2 is connected (on the bottom you must read "Found RKAndroid rock usb") and select run.
Originally posted by Huff View PostYou should use RKDevelopTool_v1.37 (https://mega.co.nz/#!uFsQ2BSB!KddUDs...hzMcGMkvouuhy8) For this.
what am i doing wrong?
thanks
steven
Originally posted by shenery View Posthi when i use rkdeveloper tool and select only kernel. it looks like it has flashed ok but when i turn on the um2 it still displays wasser 3.0.36 plus.
thanks
steven
I don't take a look what kind of version it is , i look how the movies stream and everything else is working.
There are currently 1813 users online. 0 members and 1813 guests.
