Netflix horrible quality on s89
Very odd.... For me Netflix works great and none of these issues. In fact it looks and works better on this than any of my RK devices. So there must be something else going on and other variables causing this.
Originally posted by Finless View PostVery odd.... For me Netflix works great and none of these issues. In fact it looks and works better on this than any of my RK devices. So there must be something else going on and other variables causing this.
On a positive note, this box keeps the same IP address after a reboot, that really excites me.Right now I am using the stock rom 104k4 with Finless root zip. Yesterday, I was using Finless 1.6 rom and had the same problem with Netflix.
One other thing is that there is a skylight right above my wall mounted tv. During the day, I can not see that tiny cursor, but my old eyes are not very good anymore. One other problem I have encountered, is that after my box sits for a few hours, the display is huge, can't see anything on the sides or bottom and top, I have to reboot.
Edit, testing Netflix now, and I get an audio hiccup about every two or three minutes. The video does settle down after awhile and is not too bad. If I change to a different movie, the video will lock up. I have to exit out of Netflix and start it again. Wondering if others have noticed any of these symptoms.
thanks
Netflix Verson 3.2.1 build 1346Last edited by clarkss12; 29 May 2014, 18:33.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by gopichandpai View PostBob you got one s89-h rigt? Did you test netflix on that? Was dolby available as an option in netflix?
Sent from my GT-P3100 using Tapatalk
Sorry guys, one thing I do not have is all the different equipment to test all kinds of stuff!
You have to realize that all these variables in equipment is really the issue. Might work on some, might not work on others... THIS IS ANDROID my friends! It's not always the BOX but the other equipment between the TV and the box.... Oh and YES.... the code needed to support ALL THOSE VARIENTS!....
Same here...
Just received my s89-h today....tried the stock rom with netflix, hangs after a few seconds, I can start and stop it a couple of times and it will run but very low quality and has momentary hangs every couple of minutes or so...I'm not a tester or developer but fairly computer literate....I bought through GeekBuying and the Amazon Marketplace...I will probably send it back for a refund....too frustrating to get a new device and it won't even play the basic apps that my old phone or my dual core Nook tablet will do just fine with...
Maybe a helpful post by Nowandlayda:
RK3288 Devices
- Overview BOX (LINK !)
Seriously, anyone having Netflix problems IT'S NOT THE BOX!
It works perfectly for me and better than anything I have had to date!
I am now on my 3rd movie today and I am loving it!!!
Firetv apps will not work on this box
1. you also need to load amazon app then it does check to see if its an fretv tried while back when they released the apps on xda.
JustMeBugs are Sons of Glitches!
JustMe
My netflix also messes up when i have xbmc open. Quality is still pretty bad but i'm getting less netflix problems after installing 1.6. I guess i'l try 1.6 on my other s89 and see if netflix quality is any better.Tronsmart Vega S89 Elite Amlogic S802 with finless2.0
Tronsmart Draco AW80 Meta Allwinner A80 Octa Core finless1.0
It seems to me that when I open Netflix and play the first item, it is very blocky for a minute or two, but the next item I play is pretty good right from the start... never as sharp as a Chromecast, but good._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
This may explain some of the problems that folks are having with Netflix - http://www.digitaltrends.com/home-th...etflix/#!UMVwC
As Finless Bob has said, for the most part its not the S89 thats the problem.
Originally posted by Boris Blank View PostThis may explain some of the problems that folks are having with Netflix - http://www.digitaltrends.com/home-th...etflix/#!UMVwC
nothing to do with isp I can tell you now
1. quality is perfect on apple tv box and western digital box and also on pc via website Netflix no blotihness or buffering on the highest setting of 3.5g an hour
now these boxes I'm sure they are lesser spec's than the s89 or m8 etc, so it either the decoding or network buffer tcps etc or the way it get decoded
my speed to the US servers are around 2 - 2.5 Mbits
So it the s89 or m8 square issue weather it due to licencing or codec or weather the buffer cache needs to be adjusted
JustMe
There are currently 1539 users online. 0 members and 1539 guests.
