I think I'm going to have a read up on all this rom milarky, got any sites that would be a good starting point you could point me at finless.
Tronsmart S89 STOCK ROMs (101k4) in ZIP update format
Still same problem with paid apps and msettings has stopped.
//Magnus
Originally posted by Drum View PostFinless - just a note /reminder - this ROM has remote keyboard error issues (no CAPS lock, etc), same as original ROM, whereas the 1.2 ROM did not. I believe you were planning to use a section from the 1.2 ROM in the next issue to correct this.
I was going to hold off making it as I was expecting a fixed ROM for 5G from Tronsmart (or Beelink) but now I am not sure if one is coming since Eric says 5G works for him?
Originally posted by nutzu View Postit works for him,but for us doesn't I don't know what kind of Rom is using
Well all in all, i don't mind a bit. Eric at least brought us something to tinker with. It fixes some probs. This is obviously a beta from factory to fix show stopper bugs that can't wait. I'm greatfull for that! This will be resolved soon.Last edited by Lokie; 05-02-2014, 19:04.
Originally posted by Lokie View PostDamage control until the fix arrive... After labour day. .
Mmmm.... I got the standard and updated 101k4 (finless zip). This was done over finless 1.2. Rootrd with finless root update zip. Then gotham rc1.
Everything is working well for me. I don't have 5ghz wifi router so thats not bothering me too much for now. All my movies an tv shows stream just fine like before.
Antutu is scoring 31620 after running the unit for 2 days straight. No hangups. Takes a while to wakeup sometimes but always do. (put it to sleep and somtimes).Last edited by Lokie; 05-03-2014, 07:12.
Originally posted by Finless View PostNo, this release contains bootloader since it changed from 100K4 to 101K4.
//Magnus
Problems after upgrading to 101k4
After upgrading to the new Stock firmware I found two problems:
1) Antutu Benchmark will freeze the box (have to disconnect from power adapter to restart)
2) Netflix couldn't be uninstalled (well, I can uninstall, but it will re-install after next reboot)
Also it's really annoying, that all shutdown apps on Google Playstore don't shutdown the box, but instead will reboot the box.
Originally posted by kurthv View Post1) Antutu Benchmark will freeze the box (have to disconnect from power adapter to restart)
Originally posted by kurthv View Post2) Netflix couldn't be uninstalled (well, I can uninstall, but it will re-install after next reboot)
Originally posted by kurthv View PostAlso it's really annoying, that all shutdown apps on Google Playstore don't shutdown the box, but instead will reboot the box.
Originally posted by Lokie View PostGood news!
Beelink released new firware with XBMC adio/video sync fixed
Bob? I think this can help you with your ROM?
There are currently 1144 users online. 4 members and 1140 guests.
