I've been trying 4 hourse now and it keeps on loosing connection after a few megabytes. I would realy appreciate it if somebody can upload this to a faster site... anyone??
Tronsmart S89 STOCK ROMs (101k4) in ZIP update format
Originally posted by Lokie View Post.. if you can get it to download before the end of the year!
I've been trying 4 hourse now and it keeps on loosing connection after a few megabytes. I would realy appreciate it if somebody can upload this to a faster site... anyone??ok i will try now to see if on my side work better
Originally posted by toro View PostFinless will this ROM Tronsmart S89 STOCK ROMs
be compatible with the NEW Tronsmart Vega S89-"H" version?
Thanking You
Originally posted by benny638 View PostI want to delete the Netflix, mxplayer, and xbmc apks from this directory (/system/usr) but its telling its read only . When I try to change permissions for the folder using ES file explorer it tells me operation failed. I would appreciate any help. Thanks.
problems install Rom
Hi all
I'm having trouble installing this Rom, when it goes into recovery it can't seem to mount the sd card, n gives an error something like file or folder cannot be found
My device is rooted n I'm following the institutions to the tee.
Any help will be much appreciated
Unable to install from zip files
I have a tronsmart s89 standard
updated to 101 with usb burning tool
i am unable to install this or any other zip files from finless (101 stock, root, 5ghz patch)
these are the steps i have taken
> formatted an sd card into fat32 and loaded the zip file
> put the sd card into the vega s89
> went to the update tool, selected the zip file and pressed update.
> confirmed the update
> it goes into recovery mode. i ask it to look in ext
> it throws an error saying unable to mount.
Please advise.
thanks
sai
Update:
I tried a few SD cards with little success before writing this post. Tried again with a USB pen drive instead ... And it worked. Pen drive was formatted to fat32.
not sure is this would help with you.
my vega elite, would not see the microsd.
also would not see the usb burning tool.
so, i bought an usb microsd adapter. plugged it into the usb port.
a standard usb stick may also work as well.
the update tool app was able to see that device.
was able to update firmware rom that are in zip format.
so far no problems.
Originally posted by ess2k View PostHi Lokie
Thanks for your reply, I have tried EXT udisk as well as sdcard with no luck, any other suggestions would be appreciated.
Your port could be faulty. Also try to format? Must be fat32. Use some liw level formatter like hp format on pc.
If you can see the sd card in Android then at least the port is not faulty and its probably just a formatting issue.
There are currently 1468 users online. 5 members and 1463 guests.
