Arnova Child Pad Finless ROM???
    Originally posted by MagicArc View Post
    Been waiting for this thanks! I'll test it as soon as i get home, does the zip file have instructions on installation? Also how does this differ from the update Archos posted on their site? Is it simply the same ROM with play and root enabled? Does this rom also allow for Netflix and the other blocked apps to work?
    Thanks,
    Magic
    It is built from the Arnova ROM posted on thier website
    It is rooted and Google Play is installed.
    Yes instructions are inside but see the post above from 88cavalierz24 for how to enter flash mode.
      Any word on Netflix?
        If you search netflix here on this forum, you will see it is a MISS of working almost all the time. Not just Arnova but polaroid, nextbook, etc. It seems they have a crappy APP that will not run well on tablets.
        I have YET to find someone that was happy with netflix on any 1ghz processor tablet.
          i have tried netflix and havent gotten it to work, the app loads and thumbnails take awhile, i can scroll through the titles but cannot click on anything. It makes a sound like it clicked but nothing happens. Sucks wish it would work, oh well thats why i got a 32gb microsd card for it.
            Right, i'm in the same boat. Would love netflix to work. I'm majorly just wanting root so that i can block the adds. I don't think my 3 year old needs to be playing games and seeing ads for dating sights. I've got my 16gig sd card ready to load up with movies.
            Any idea how to change the default path for the "movies" folder/app. I want it to point to the sdcard or a folder on it. Load that bad boy up with reading rainbows and pixar flicks.
              Gotcha. Thanks again for all your work on this. Hopefully someday their app will be friendlier to the the 1ghz tabs.
                Step by step procedure
                Hi guys,
                I'm a newbie to all of this. I downloaded the zip file, unzipped it to a known folder and I tried all the (partly) described procedures, but I never made it to the point of successfully installing the drivers.
                May I kindly request you to write a precise step by step (debug mode Y/N, buttons to push on boot...) procedure to install this ROM.
                Thanks in advance
                Sergio
                  Installing Rockchip drivers for flashing!
                  Originally posted by sergiod1958 View Post
                  Hi guys,
                  Thanks in advance
                  Sergio
                  Please follow this guide to get your drivers installed.
                  Follow the posts earlier, to get you tablet into recovery mode. Once in recovery mode Skip part 1 and 2 and go straight to part 3 of the guide
                  </form>
                    my device after flash does not work more
                    hello please help me ,,
                    i make the flash , after the device boot,
                    and stop to the 1. point language and calibrate the display .. now there is a point " please touch this point"
                    but the touchpad dond work .. please help me
                      Arnova says they will be releasing many versions of the childpad. This ROM is based on the ONLY ROM available from arnova which is for the Alvin Resistive version:
                      Diese Website steht zum Verkauf! arnovatech.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf arnovatech.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
                      If you have some other model then that is a problem. Maybe you have capacitive? Arnova has no available ROM for any other version other than that. Try flashing back to the stock ROM from thier web site.
                        Child pad Arnova AN7DG3
                        Hi thank you for your answer ,,
                        my model is AN7DG3 ChildPad. yes it is capacitive .
                        how can i " Try flashing back to the stock ROM from thier web site " do that ?
                        With RKandroidTool ?
                        Thanks you
                          I am afraid the stock ROM will not work for you! The stock ROM is a resisitive.
                          Model is:
                          AN7DG3ST-CP
                          Arnova does not have a stock ROM for the capacitive at this time
                          Maybe soon they will. You can try to ask them for a release of it. Or we need a stock ROM dump from the capacitive version.
                          It may also be possible that the non-childpad 7dG3 ROM will work for you. There is a ROM dump out there but it appears the site that has it is hording it
                          They have had it for weeks now but for some reason are not releasing a stock ROM dump and waiting to release a custom ROM first instead. That is bad for people that need it
                            Model is:
                            AN7DG3ST-CP
                            So to clarify, the Finless ROM is for the Resistive version only? If so do we have a way to root Capacitive version?
                            A few questions, what is the model number for Resistive and what is the model number for Capacitive.
                            I have a AN7DG3ST-CP...my guess would be CP is for capacitive? If i'm incorrect please let me know. I'm thankful now that i havent flashed with the new rom.
                            Magic
                              chidPad AN7DG3 - &quot;Capacitive&quot;(on the Package)
                              Magic
                              Yes it is done, i did put the wrong rom , that for the Resistive.
                              my Pad is 2 day´s old.
                              Is there no chance to make them work, as only wait for Arnova relase a rom?
                              If someone as a idea please help me ,
                                my Pad is 2 day&#180;s old.
                                What you need is somebody with the same. Tablet as you to do a rom dump so. That a rom can be made for you.
                                So.we need somebody to come forward
                                Sent from Xperia Mini Pro ~ Android 4.0.4 ICS
                                </form>
