QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
Originally posted by Lovetz View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by benster1 View PostHow do i set setenforce permissive?
Im getting confused
Verstuurd vanaf mijn HTC One met Tapatalk
#!/system/bin/sh
setenforce permissiveThere are 10 types of people in the world: Those who understand binary, and those who don't...
Re: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
Originally posted by avia View PostWhat about the possibility of afp - from the time capsule to minx they do not see each other.There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Postsorry but I don't know what are you taking about, afp? time capsule? can you please elaborate on that? thanks
Time Capsule - http://www.apple.com/airport-time-capsule/
afp - Mounting shared folders using an afp:// URL or the mount_afp command
You can mount a shared volume on an AFP server with a URL in the form of afp://myserver.mydomain.com/Sharepoint/Folder, or in Terminal you can use the mount_afp command.
Originally posted by daemonium View PostEdit the nfs script, and make the first two lines look like this:
I can do a quickflasher or quickshot-update.zip patch if you want, but it's a pretty easy modification.
My own 017mount nfs?
Man nothing works when on v2 it works.
Again.
My videos are located at 192.168.1.15:/Multimedia/Video
Do i need to make a new script?
Do i need to edit anything,?
Do I use the 97nfs script located at init.d?
Again.
In your case :
mkdir /mnt/Video
busybox mount -o rw,nosuid,nodev,nolock,rsize=32768,wsize=32768,int r,noatime 192.168.1.15:/Multimedia/Video /mnt/Video
2/Save script, and change permission file 97nfs to 755.
3/Reboot
That's it!
Originally posted by roolmapool View Post1/Use 97nfs located at init.d -> edit/add/delete lines of script to suit to your NAS path and local folder path is /mnt/xxx IMPORTANT! don't work with /mnt/sdcard/xxxx
In your case :
mkdir /mnt/Video
3/Reboot
That's it!
How do i set it to 755?
Im sorry ask so much i am not good at nfs mounts. My old nfs script was hard to get hahhaha
no problem mateThere are 10 types of people in the world: Those who understand binary, and those who don't...
Verstuurd vanaf mijn HTC One met Tapatalk(Thx btw for command!)
Originally posted by kokoui View PostI am trying to change the 95screen_zoom file but system is not letting me. I even connected as root in terminal and trying to replace file but with no luck
mount -o rw,remount /system
---edit your file to suit your needs--
back to terminal as root:
chmod 755 /etc/init.d/95screen_zoom
mount -o ro,remount /systemThere are 10 types of people in the world: Those who understand binary, and those who don't...
Odp: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
Originally posted by daemonium View PostWe will try to dig on libmedia code to figure that out. But it will take us some time, it's not easy.
Btw
Is hard to back from "kitkat" to jelly bean?
There are currently 2175 users online. 0 members and 2175 guests.
