QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
    Originally posted by Fedur View Post
    Quickshot v2 is good, all works, when v3 will be good as v2 i will update it for sure . Just need passthrough with xbmc.
    Btw
    Is hard to back from "kitkat" to jelly bean?
    We posted a link on the first post for this http://www.freaktab.com/showthread.p...back+jellybean
    BTW for me QS3 is as good as QS2, Quickshot is much more than just xbmc.
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
      Originally posted by benster1 View Post
      Thank you.
      How do i set it to 755?
      Im sorry ask so much i am not good at nfs mounts. My old nfs script was hard to get hahhaha
      Verstuurd vanaf mijn HTC One met Tapatalk
      Originally posted by daemonium View Post
      chmod 755 /etc/init.d/97nfs
      no problem mate
      Originally posted by roolmapool View Post
      1/Use 97nfs located at init.d -> edit/add/delete lines of script to suit to your NAS path and local folder path is /mnt/xxx IMPORTANT! don't work with /mnt/sdcard/xxxx
      In your case :
      mkdir /mnt/Video
      busybox mount -o rw,nosuid,nodev,nolock,rsize=32768,wsize=32768,int r,noatime 192.168.1.15:/Multimedia/Video /mnt/Video
      2/Save script, and change permission file 97nfs to 755.
      3/Reboot
      That's it!
      After some try and error attempts, i got all my NFS shares working as expected...
      For some strange reason , the first mount in the list is not working, when pointing to /mnt but second and third are working pinting to /mnt/internal_sd/nfsvideo and /mnt/internal_sd/nfsmusic (this two folder you need to create manually).
      So i put a first mount to a share i dont need to mount, and two other ones (nfsvideo and nfsmusic) are mounted fine
      this is the script:
      Code:
      #!/system/bin/sh
      setenforce permissive
      # Make sure networking is up before mounting
      busybox sleep 3
      # Switch rootfs to read / write
      # Be carful after this. Misplaced commands may
      # brick your system
      busybox mount -o rw,remount /
      # Create Mount Points
      mkdir /mnt/nfsphoto
      #mkdir /mnt/nfsvideo
      # Switch rootfs to read only
      busybox mount -o ro,remount /
      busybox sleep 2
      #NFS Auto Mount
      busybox mount -o nolock,rw,hard,intr,vers=3 -t nfs 192.168.1.110:/volume1/photo /mnt/nfsphoto
      busybox sleep 1
      busybox mount -o nolock,rw,hard,intr,vers=3 -t nfs 192.168.1.110:/volume1/music /mnt/internal_sd/nfsmusic
      busybox sleep 1
      busybox mount -o nolock,rw,hard,intr,vers=3 -t nfs 192.168.1.110:/volume1/video /mnt/internal_sd/nfsvideo
      Hope that helps...
        Odp: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
        Thx for link i will feel more safely nowwhen what experiment with new rom.
        I use stock minix remote. So use xbmc for watching tv, listen music, etc. I can navigate with that remote only. Thats why i use xbmc. Almost all my files have audio in 5.1 surround. Xbmc download subtitles in 1click also so no need extra application to do that. For me will be good as previous version if have same functionality. For the same reason i no use gotham xbmc on tv box because beyound xbmc have no problem with 12-15gb video files witch ac3 5.1 or dts audio.
        On gotham some 1080p with aac stereo play no smoth. To many bugs right now. Gotham is only better on my tabled because full hw acceleration works.
        In future i will buy air mouse with keyboard and will be more functionality outside xbmc.
        I have Nexus tablet and jellybean or kitkat have the same functionality. No difference for me there. All aps what use works the same. I need the same on tv box. Not only half working aps.
          from terminal as root:
          mount -o rw,remount /system
          ---edit your file to suit your needs--
          back to terminal as root:
          chmod 755 /etc/init.d/95screen_zoom
          mount -o ro,remount /system
          perfect thanks , 96 was the sweet spot for me. Great job guys , very stable rom so far for me
            So how soon before pass through is fixed? You can't have Xbmc and not have surround
            Sent from my iPhone 5 using Tapatalk
              Dude they will try to find a solution. Pass through is not yet available for kit kat. And as they said befor quickshot is not only for xbmc
                Then why does it work on the tronsmart and in mx player in here
                  READ THE THREAD.... if you had... you'd see they are going to work on it....
                  They've been working hard on the ROM as it is... at least show a little consideration for them and the work they've already done... in short... .quit whining like a child
                    I open a topic for T428 and Quickshot V3. Since everything is working for me I would be please to help anybody.
                    T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                      Not just that's the 1 big thing. That and the launcher crashes allot.
                        I have yet to have launcher3 or Apex ( my primary one ) crash once... I didn't try the Minix launcher ( yet ) so can't say anything about that one. If you are actually seeing launcher crashes... this is commonly from being OC'd too much for the hardware you have, a bad flash or another app misbehaving.
                        I have seen XBMC on other ROM's crash to the desktop previously... so if XBMC Gotham does it also, it wouldn't surprise me. But XBMC isn't the ROM... it's an app that is simply included and if you are having issues with that... then talk to the developer of it ( a link to their thread is given in this thread ).
                        As for the passthrough in XBMC being a big thing... no comment... they'll work on it as they've said and repeatingly asking when it will be fixed is just being impatient and childish
                          Does apex require a air mouse to use? That's why I use the minix launcher becaue it works with the included remote.
                            It would work.. just not well. Like most launchers... it's made with a mouse or touchscreen in mind.
                              this is the script:
                              Code:
                              #!/system/bin/sh
                              busybox sleep 3
                              # brick your system
                              mkdir /mnt/nfsphoto
                              busybox sleep 2
                              #NFS Auto Mount
                              busybox sleep 1
                              busybox sleep 1
                              Hope that helps...
                              Great thanks, this script worked for me, same deal as you first mount doesn't work (which I don't need) the others do.
                              Thank you, this ROM is now perfect for me!
                                Hopefully I have a simple problem that someone has already solved, but has eluded my searches...
                                I have problem running Netflix. I have tried multiple versions, including the one from a few days ago, and each time I get:
                                "Sorry we could not reach the Netflix service. Please try again later. (-3)"
                                When I check on my laptop, I have no problem accessing Netflix on the same connection. I did not have this issue on Quickshot v2, but I had the same problem on Wasser's KK build. How can I diagnose the root cause of this problem? Are there any general solutions I can try?
