QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
Originally posted by DroidFan View Post
USB DAC
Originally posted by DeliriumNL View PostI just finished setting up and i must say this rom is the best available and will be my daily driver for a long time !
I had a little trouble with the new NFS script, my old one was mounting to /mnt/sdcard/drive and that apparently doesn't work under kitkat (emulated folders).
My (stereo) USB DAC is working great, i have no problem with my Mele F10 pro taking over the audio because my DAC takes it over - exactly how i wanted.
The rom has been running all night and never crashed so far, I'm trying out Wasser XBMC right now and I can play 1080P files very well - slightest audio delay still but I think BeyondXBMC will fix that.
I love the way you build your roms, they are fast, clean, customizable and very enjoyable.
Only minor bug that I found is that the 'enter' key isn 't working anymore, but on the other hand - my 'home' button is working again so thats kind of funny. I allready tried a different keymap and that didn't help so I think i have to look for the new 'enter' shortcut in kitkat and map it to the remote (will share that if i find it).
This is the fastest rom I've ever used !
Very happy user and happy that I've donated, you earn it!
Could you please confirm that you have successfully play hi-res file without resampling, with your USB setup?
A2 remote
Patch for A2 remote:
-Using Quickflasher:HERE
md5 b253a8b64eb54b33c217c4860856ad20
- Using quickshot-update:HERE
md5 caef0cb2b6a783a1c64ad7a6e7495cbd
ROCKCHIP APPS PACK deleted from compilation HERE
md5 06ee1db5f25fd4bbe82094449ffeffdc
WINDOWS APP TizzNFS, to create NFS shares in a easy way HERE
md5 da7c9dc1cca712646a553e5288a30c60[/QUOTE]
Hi everyone, I'm a new user for MINIX A7 and also a novice. So I installed ROM QS 3.1 with no ploblem. Everything are working perfecly except my A2 REMOTE. See post 1, only three buttons are not working perfecly.
I used Tincore quickflasher for the first, and it not working (not valid pakage) i got.
For the second links, I don't know what to do or what I need to do it.
So, I need some can held, I need the right patch (link) and what i need (app) to install it.
Thank you! Merci!
Originally posted by iegolas View PostHi,
I installed QuickShot 3.1 in Neo Minix X7 and the media player (in the ROM, XMBC) the sound is choppy
It's not problem of the media file and I tried with several of them than before they work with the original ROM.
Thanks for your help
There are currently 3555 users online. 0 members and 3555 guests.
