QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
    Re: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
    Originally posted by eelectro View Post
    Hi Team.
    Any chance of porting this to the mini X7, just like v2?
    yes it will be done, we are working on it. Btw if i get 1$ every time i answer this question, i will be rich in a week. please don't ask before doing a search, it's hard answering the same questions over and over again.
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
      Originally posted by daemonium View Post
      standard kernel is 1080p
      I just finished setting up and i must say this rom is the best available and will be my daily driver for a long time !
      I had a little trouble with the new NFS script, my old one was mounting to /mnt/sdcard/drive and that apparently doesn't work under kitkat (emulated folders).
      My (stereo) USB DAC is working great, i have no problem with my Mele F10 pro taking over the audio because my DAC takes it over - exactly how i wanted.
      The rom has been running all night and never crashed so far, I'm trying out Wasser XBMC right now and I can play 1080P files very well - slightest audio delay still but I think BeyondXBMC will fix that.
      I love the way you build your roms, they are fast, clean, customizable and very enjoyable.
      Only minor bug that I found is that the 'enter' key isn 't working anymore, but on the other hand - my 'home' button is working again so thats kind of funny. I allready tried a different keymap and that didn't help so I think i have to look for the new 'enter' shortcut in kitkat and map it to the remote (will share that if i find it).
      This is the fastest rom I've ever used !
      Very happy user and happy that I've donated, you earn it!
        thanks for the feedback and also for the beer :P
        we are going to release a update soon fixing some issues and adding some features too.
        there's a nfs script included on the init.d folder, we have been talking about this some posts before, I suggest you to read that posts it will be helpful
          the default kernel is 1080p by default, open a full hd movie with xbmc and you'll see.
          Thanks for your reply !! yes I can see that but why setting shows I am getting 720 not 1080? when I try to change that I wont change it. when I switch tele and it also shows I am getting 720
            can you please describe the exact steps you do? i will have a look at that
              1080p KERNELPACK FOR QUICKSHOT-UPDATE
              This link is dead can anyone pls reup ?
                NFS is working. No problem. But had some trouble in the beginning :-)
                Update will be cool !
                Only thing I could wish for is : able to Turn off sounds when clicking something in menu of android, HSL Smooth streaming (for example NPO app stops playing video after buffer is empty (5min)).
                  sorry i don't know that app, i use splive tv for rtmp stream lists and it works perfectly. Maybe this issue is app related, do you know if it works on any other kk rom for x7?
                    A lot of apps use the HSL Smoothstreaming method, NPO is just an example, it works fine on both my KitKat tablet and KitKat phone.
                    This problem has already fixed for 4.2.2 (Hardwareguru 4a) rom for MINIX X7 but sadly he is not responding
                      i will read about that, never heard of hsl :S
                      edit: http live streaming, now it sound more familiar
                        Basically it allows the streaming to start on low quality and then decide to move to high quality when the band with allows it !
                          i will have a look at that, let's see if i can fix it for the upcoming update.
                            I can give you my login for the app foxsports so you can test it.
                            Verstuurd vanaf mijn HTC One met Tapatalk
                              thanks i will pm you if i figure this out
                                mini
                                Originally posted by Fedur View Post
                                You have full neo x7 or mini version of tv box?
                                We have the mini
