QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
    Originally posted by kRel View Post
    I use a DAC between Minix and my HiFi stereo.
    With V2 The DAC and high quality music works perfectly! Can I expect the same thing with the V3?
    (I have not yet installed the V3 because the audio is a priority for me. As long as I'm not sure how to get back without brick, I can not install the V3)
    looks interesting oO
    can u post the product itself?
    maybe it will buysomone of these
    thx
      Originally posted by leolas View Post
      Can you please post an screenshot where we can see the exact name of the device that appears in settings?
      I think that we found how avoid this problem with a2, but I need your exact name to try to make it work for your remote too.
      Leolas
      Sent by my phone.
      Enviado desde el telefono.
      Thanks a lot.
      P.S One weird thing that happened to me today is when I restarted minix I opened xbmcZ and it fallbacked to your skin ( I had changed it before) and also I lost some language settings, very weird..
        Kokoui,
        It has been well documented that remotes with audio will cause the MINIX to default to those speakers regardless of the ROM you are using.
          Re: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
          Originally posted by sheg0 View Post
          Hey guys,
          Is there any possibility to get audio out of both sources in this Rom?
          I often listen to music when TV is turned off and mute the speakers while watching in Xbmc. Tried various settings but can't find a working one.
          Regards,
          Sheg0
          I am also interested. I need HDMI to TV un stereo mode AND spdif passtrought to my amplificator.
          Regards,
          Enviado desde mi Xoom Wifi mediante Tapatalk
            Hahaahha i tought let me be smart and fix the low resolution on the apps npo and rtl xl.
            Put in the exact build prop of an samsung s4!!!
            No luck but had a good laugh!!
            The screen was up side down and the resolution still mega low.
            Good thing i backed up my build prop.
            Sorry nederland. Nog geen oplossing gevonden!!!
            Sorry dutch guys
            Still no solution found!!
            Good night freaks tabberss
            Verstuurd vanaf mijn HTC One met Tapatalk
              Problem
              Mistakenly eraseIDB in RKAndroidTool
              The device does not work
              What is the solution
                Reflash the same rom you were before the mistake! It's my guess, btw I am no expert!
                Inviato dal mio Nexus 5 utilizzando Tapatalk
                  Computer does not recognize the device
                    Originally posted by jacknjill10101 View Post
                    Kokoui,
                    I know but leolas is preparing a fix and he asked for a screenshot to see exactly the name of the driver
                      R: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
                      Try to keep power button pressed after you released the reset hole pin, for the whole duration of the flashing of the rom you were before.
                        push the power button and the reset button and hold. does the pc recognize now?
                          Thank you very much - شكرا جزيلا -
                              Regards,
                              I use HDMI selector with toslink and stereo output.
                              T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                                Odp: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
                                Regards,
                                When I use hdmi passthrough or spdif passthrough i have surround sound on 5.1 speakers and stereo on panasonic plazma tv. Its normal in my setup. What is difficult with that?
