QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
    Originally posted by SUNUN View Post
    I have the same issue and i have use the same cable, but now i will try another cable. But one question, are you shure this is a cable problem?
    tried 3 cables problem still exist screen sometimes is blinking
      Re: QUICKSHOT V3 by TheNitroTeam MINIX Neo X7.
      Originally posted by berrani View Post
      Please, help me, i tested qs3, but I prefer to return to qs 2: I read I have to delete nand with flash tool for kitkat, but where can I find it?
      Thank very much for any help
      look at the first page of this thread.
      There are 10 types of people in the world: Those who understand binary, and those who don't...
      If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
        get a good quality one. low quality does this.
          I will make a zip with the rktooldevice, give me some time.
          I can't be absolutely sure about live 2 minutes after post this, daemonium had your same problem, and he solved it changing the cable, I don't have your same TV, nor your exact same x7, and I cant reproduce this problem, it sounds to me like loosing HDMI connection and awakening.
          like daemonium said for me it is caused for use low quality hdmi cables. He had your same problem and he resolved it using a best quality cable.
          Originally posted by benster1 View Post
          Live streaming apps are super now with hls. But the rtl telekids is still very low resolution.
          Verstuurd vanaf mijn HTC One met Tapatalk
          Sorry a lot, but there are problems with some apps in all my devices, phone, tablets, TV box, but we can't test all apps are working is impossible. I never used Hulu plus (I suppose you are referring it), is an paid app? Need subscription? Does it work in all countries?
          Let me a couple of days and I will make a kernel to be tested only for people with this problem.
          Leolas
          Sent by my phone.
          Enviado desde el telefono.
          My devices:
          Gearbest.com)
            not trying to hijack the thread. I just want to let the devs know the ROM works in my mk908-ii with d33's generic KK kernel.Great work!
            MK808B Plus, MK908II
              People should be advice apk are not all tune for kitkat, lot of them install but not running well. Usualy it's specified in apk résumé.
              T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                I refer to the possibility of going back to KK JB:
                The KK flashtool is perhaps RKDeviceManage.exe included in zipfile NeoX7-Windows-Flasher-QS3-en.rar ?
                What is Jelly Bean flashtool ? I do not know because for install Quickshot v2 (JB), I used CWMrecovery directly from Minix.
                Which tool should I use flash V2 please? Perhaps RKAndroidTool.exe contained in zip file QuickShot_V2.rar ??
                Thanks for v3 !!! I hope it's excellent as v2 !
                I used CWMrecovery directly from Minix! Help please ...
                  How to fix dark video playback
                  I finally made the jump from a mk808b to the Minix Neo X7 (QS3) and I am very happy with the box but video playback is too dark. I tried to look around for fixes before posting but I have not found any. Any help would be great.
                    That's a known and common problem. Is a matter of hardware. Try the app "screen adjuster", some people find it useful.
                      Originally posted by daemonium View Post
                      Try another hdmi cable, this issue is something we are digging into.
                      no luck. 3 cable, no one work. i used the original one, one midrange and one high quality. i will roll back to qs-2 until this issue is fixed.
                        There's another method to do that but i personally didn't try it, my team mate litry did it and it worked for him.
                        Download the qs2 zip , the one is for flash from pc.
                        -Disconnect all
                        -Run RKAndroidTool included in the qs2 zip file
                        -Attach the usb-microusb cable to pc (usb side) and tvbox (microusb side)
                        -Attach the power cable
                        -Push and hold the reset button
                        -Push and hold the power button, don't release the power button until the end of the process
                        -When RkAndroidTool detects the tvbox you can release the RESET button, but still hold the power button
                        -Click on eraseIDB button
                        -Click on run , still holding the power button, and wait until the flash ends. When it's done you can release the power button.
                        Hope this helps.
                          Leolas
                          thx dear friend i will wait for your kernel, because i use high quality cable and in your QS2 Rom it works fine.
                            I have several cables, the first one i was using was broken , i changed it to another one, a good quality one and it worked (and still it does). Lately i've been trying the low quality ones i have, but all of them have this issue. One of our theories is the low quality ones do bigger resistance than good quality ones so we have that shut off and shut on (sleep and awake). We are going to try a kernel with some values changed to try to avoid this. We hope it will work so you can go back to qs3 later
                              -Disconnect all
                              Hope this helps.
                              It works! Thanks for the great work!!!
