Ugoos UT2 - wasser firmware - KiKat Android 4.4.2
    version 1.0.1
    - perfect 1080p fullhd video streaming
    - multiuser support
    - usb webcam support
    - autohide status bar
    - multi usb partitions support
    - busybox up to date
    - google apps up to date
    - hardware keyboard support
    - lock screen support
    - google searchbar is disable by default
    - screen rotation support
    - enable tun in the kernel
    - notifacation sound support
    - reboot/sleep/bootloader mode dialog
    - init.d support
    - ir-remote, A2 Airmouse support
    - cwm recovery support
    - ntfs, nfs, cifs filesystem support
    - rooted
    Link download: wasser-firmware-ut2-1.0.1.zip
    please use RKBatchTool to flash the new firmware
    link download for wasser-xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.0.apk
    Be aware: it is your own risk!
    KiKat-4.4.2 for Ugoos UT2
    Can i flash this version 1.0.1 for T-R42 V2.0?
      wifi and ethetnet won't work if you flash this firmware, because of different hardware
      wasser
        Is there any problem flashing back to JB Wasser V1.25 if this KK version buggers up or someone doesn't want to use it after all?
        Just asking because I read somewhere here that going back to JB from KK requires you to erase nand with one program and reflash JB with another....???? something like that....
        FLHT = Harley
        HEMI = 2010 Dodge Challenger SRT
        Cause I've been asked.
          there's good docu about this, Please take a look at this
            Thanks Wasser.
            i'm going to try it
              THANKS Wasser
              waiting for this, ill report back once flashed
                Good job wasser, nice clean rom.
                Do you think there is any hope to get XBMC HDMI sound passthrough working in kitkat?
                  You guys liking this ROM? Is working OK or lacking anything?
                  Thinking about a flash but want to see some reviews
                  FLHT = Harley
                    spdif passthrough works
                      I cant seem to get this working, any hints?
                        Very NICE and clean ROM! I'm loving it!
                        Wasser! Thank you for making it so clean...
                        It's Clean! It's Rooted! It's Bloatless!
                        With Beyond XBMC 3.3 it wasn't all that great, so I switch to XBMC Gotham 13.1 Beta 2 and that seems to play and stream very smoothly.
                        I like the fact that I have plenty of space for apps as well.
                        Testing will continue and will report back if I find any issues, so far none!
                          you need my libmedia.so hack for spdif passtrought support.
                            works great
                            i like that i can use my minix remote so thanks
                            the auto hide taskbar is handy now so no need to close for xbmc anymore.
                            runs smooth
                            overall a great rom
                            also its now a nexus 7 lol
                            thanks!
                              wasser-xbmc-v1.0
                              Hi all,
                              i have built xbmc based on gotham 13 for my wasser firmware. 1080p video playback is perfect. Please take a look at the first post to get the download url for wasser xbmc.
                              Enjoy
                              wasser
