Ugoos UT2 - wasser firmware - KiKat Android 4.4.2
    Hello you All, maybe you someone help me, i don't know what to do anymore.
    I don't get the 1080P smooth....and that's why i bought the Ugoos....to start with tv boxes....
    I tried 5 different roms (wasser, justxbmc....original), but no succes with playing MKV 1080P.....it's always shocks and when the xmbc overlay buttons are on the screen, the movie will stop playing and become blocks on the background. Also much buffering, network driver ugoos problem?
    What do i wrong? Ugoos defect?
    I have a Apple airport router, 1Gb lan, usb hub and 5 Ext. Harddrives (Apple HFS formatted connected to router)...no wireless all trough CAT6 cable. My Asus O'play and AC Ryan are using the same Lan port and work 100%....all the tablets on android streams well 1080P.....only not the Ugoos.
    If someone can help me or have useful tips.....please let me know.
    thanks allready.
    greetz Hans.
      hello wasser
      very nice rom :-)
      I've a question: since I want to buy an air mouse, the only one supported is the minix a2 or other air mouse can work flawlessy? moreover which fly mouse would you suggest me?
      thx for the reply
        Originally posted by galock View Post
        hello wasser
        very nice rom :-)
        thx for the reply
        Minix A2 works perfect with my firmware.
          thx for the reply
          unluckly on amazon I've read quite bad review about this remote :-(
          does anybody else uses a nice remote working on wasser kitkat rom?
          ..and moreover how can I know if a remote I'de like to buy is compatible with wasser kitkat rom? ....I was interested in buying rii i5 remote but if I don't know if it works...
          PS I was watching you tube video on beyond xbmc but the mini pc switched off. I had to plug and unplug the power cord in order to be able to restart it
          is it something related to xbmc beyond? maybe xbmc gotham doesn't have these kind of issues on kit kat roms?
            Original remote issue with XBMC Gotham 13.2 B2 and Wasser XBMC
            Wasser,
            I notice a remote control problem that occurs with both original Gotham 13.1 Beta 2 and Wasser XBMC v1.0. At most times the remote would functional normally, but when you need to click on a link to stream something and the on screen keyboard pops up, at this particular time the remote (original included w/UT2) would not allow you to enter any characters into the field. If this happens any link requiring a code to be enter (i.e. HugeFiles, 180upload,etc..), would not work. Putting the remote in mouse mode won't all characters to be selected either.
            This problem does not occur when using Beyond XBMC v3.4. The remote would work perfectly fine.
            Secondly, in Android when click on the App Menu, it would go into the App Menu but selection option is not available you would have to go back to Home menu and come back in a second time to be able to select any app.
            Is anyone running into the same issue? I have a couple of Ugoos UT2 and they all have the issue running Wasser KitKat 1.0.1 rom.
            Thanks!
              Originally posted by mxcoinc View Post
              Wasser,
              I notice a remote control problem that occurs with both original Gotham 13.1 Beta 2 and Wasser XBMC v1.0. At most times the remote would functional normally, but when you need to click on a link to stream something and the on screen keyboard pops up, at this particular time the remote (original included w/UT2) cease to operate, therefore you can't enter any characters into the box. If this occur links to any stream that requires a code to enter, would not work. Putting the remote in mouse mode won't work either.
              Secondly, in Android when click on the App Menu, it would go into the App Menu but selection option is not available you would have to go back to Home menu and come back in a second time to be able to select an app.
              Thanks!
              I have not seen the problem with the first part but do have the same thing happining on the second. I use wireless Logitech keyboard KR400 when typing.
                You haven't seen the first part. Do you use the original remote included with your Ugoos UT2 at all or just your Logitech? If you have the original remote please test with a stream such as HugeFiles or 180uploads, to see if you have the first problem as well.
                Thanks!
                  Thanks!
                  mxcoinc I just checked with the original and indeed do have the same problem.
                    Wasser,
                    Thanks!
                    it's known bugs. it's on my todo list ;-)
                      Got my UT2 today! Playing around with it now, think I'll flash this tomorrow.
                      Wasser, for performance/stability would you recommend this firmware or your JB version?
                      Sent from my SM-G900F using Tapatalk
                        Gotta say, this is a very good rom. Will you be continuing development?
                        I'm using your xbmc and everything running nicely.
                        Only problem is I've had a few random shut downs. Screen goes multi coloured and fuzzy then device powers off. Each time it's happened I've had music playing on Spotify, not sure if spotify causes it though.
                        Has anyone else encountered this?
                          sure, i will continue to developemnt for UT2.
                          it seems you have 3188t, This issue could be happen on such device with 3188t.
                            Re: KiKat-4.4.2 for Ugoos UT2
                            I don't think so. I checked antutu and it's showing 1.6ghz. This means it's not a T chip, right?
                            Also, I bought from geekbuying who I believe don't sell sell the T variant.
                              it could be that you are using the oc kernel which removes this cpu lock, Please try the stock kernel
                              and check again.
                                and check again.
                                I never changed the kernel, only flashed your rom. Does this change the kernel (sorry I'm still learning!).
                                Also, I ran antutu before flashing anything because I was finding stock quite laggy and was worried I had received the T variant, that's where I saw the cpu speed.
