Inviato dal mio Galaxy Nexus utilizzando Tapatalk
Ugoos UT2 - wasser firmware - KiKat Android 4.4.2
Originally posted by dimarik83 View PostWasser forgot about us
i have asked Ugoos a month ago to provide me some technical infos which i need to fix some issues in my firmware but haven't got any answer yet and i'm still waiting....
It seems Ugoos doesn't have interest to coorporate with me. I don't want to release any my firmware when i know it doesn't work correctly.
sorry!
wasser
sorry!
wasser
Your 4.2.2 version for UT2 works good for us. - no issues
I have little request for you, if you can help me,
I am trying to switch the internal VFAT file system to ext4, and i modified recovery to change vfat to ext4.
It is formatting correctly, but it is not mounted automatically on boot.
When I mount manully (ADB shell), it works.
I am not sure how to add this script on init.d logic.
Can you explain me how to setup init.d script.
also, do you know to add fsck to /data/ and /cache and my new ext4 partitions on every boot?
I can modify the system.img using RkRePacker tool.
Thanks a million for your good work.
[QUOTE = Wasser; 203396]
я спросил Ugoos месяц назад, чтобы обеспечить мне некоторые Техническая информация, которую я должен исправить некоторые проблемы в моей прошивки, но не получил никакого ответа еще и я все еще жду ....
Кажется Ugoos нет интереса к Институциональные со мной. Я не хочу, чтобы освободить любую мою прошивку, когда я знаю, что это не работает.
Извините!
Wasser [/ QUOTE]
Clearly,it is a pity that development stopped for this TV box. I now put your firmware from minix x7 (Wasser 1.0.4) and it works fine in conjunction with the kernel from QS 3.1 Nitro,but does not work recovery stage and sd card after rebooting falls off,it's necessary to pull out and insert,but this is not a significant problem in the rest of the firmware is great,the video shows smoothly.
Re: Ugoos UT2 - wasser firmware - KiKat Android 4.4.2
sorry!
wasser
Do these guys not realise we're buying their product because of people like wasser??
Sent from my SM-G900F using Tapatalk
Wasser
Have you tried these guys http://allminipc.com/forum/
They seem to be on the UGOOS website and already have a kitkat release
For all those still having issues with this firmware crashing, I can confirm that wasser's Minix X7 firmware works perfectly on the UT2. I've had the device on for 48 hours now and no random shutdowns at all.
Highly recommended.
Originally posted by wasser View Poststill zero response!
Wasser
Originally posted by Bazmamfoo View PostFor all those still having issues with this firmware crashing, I can confirm that wasser's Minix X7 firmware works perfectly on the UT2. I've had the device on for 48 hours now and no random shutdowns at all.
Highly recommended.
http://www.freaktab.com/showthread.p...-Android-4-4-2I have to use a combination of a wireless mouse and the XBMC official remote app on an old phone. So I would love to see this FW fixed, just the couple little bugs that have been found that's all....
Looks like wasser has been around but nothing new since August...can these minor issues be fixed without Ugoos being involved?FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by flhthemi View PostI just installed it too....works good the only thing I miss is the use of my UT2 remoteI have to use a combination of a wireless mouse and the XBMC official remote app on an old phone. So I would love to see this FW fixed, just the couple little bugs that have been found that's all....
Originally posted by Hogger View PostWhat kernel are you guys using ? I got the UT2 32gFLHT = Harley
There are currently 1639 users online. 3 members and 1636 guests.
