Finless 1.5 ROM ported to the EM8 BETA-1
Hoi Bob,
The finless-rom is running great and 1280-720 too! I installed oman XBMC and runs 720 also.
Google play took some time, but nevertheless, it's working fine.
Thanks for the cpu-fix and back to stock. The cpu-fix-800 gave me an signature error updating from update-apk, but did install fine from within the bootmenu.
My Trust keyboard works good (although not my shutdown button), and the remote works ok too.
Is there a way to "fix" the external sdcard1 the way android kitkat "mounts" it? So i can mount a ext3 formatted sdcard (now only fat/ntfs) and move apps to?
"My Nexus 10" Antutu score 23973 with cpu-fix-800 (with reported ram speed 1345...).
FTP (ftpdroid and Filezilla on w8.1) score over utp cable with 200mb file: ca. 5mb/sLast edited by Marton4; 24 May 2014, 14:21.
Originally posted by TMx View PostIs there any chance to change the keyboard back to Stock cos I can't use Finless Keyboard with Remote controller...
Thanx
FYI that's not the Finless keyboard. That is the stock AOSP keyboard. I removed the other keyboard as most don't like it.
Download this zip. Do not unzip it. Put it on SDcard and install it the usual update way. Easy way is to use the update APP. This will install the Remote Keyboard Input Method that I removed from the ROM.
https://drive.google.com/file/d/0B9B...it?usp=sharing
To use it:
1) Go to setting and Language and Input
2) Turn on the Remote Keyboard Input Method (check box next to it).
3) Go into Default (click the line) and select English - Remote Keyboard Input method.
Your done and now have the other keyboard back.
And for testing which keyboard suits best, can you make such a zip file for the keyboard currently in your rom?
Do i need to use such a zip file, or can I use putty to switch those keyboard.xml files? I only found a keyboard.xml in the cache (and an empty keymap folder in de userdata folder), but that gets removed after clearing the cache. You know the location of the original keyboard.xml file?
I am not sure what your asking. When you install keyboards they show up in the settings menu as I have explained.
Keyboard mappings are in /system/usr/keylayout/*.kl
Generic.kl is the stock keyboard. Other .kl files are for other keyboards, joysticks, etc.
There are also mappings in /system/user/keychars/*.kcm
These files can be modified easily as they are text files.
There are also some remapping apps in the play store to do it as well.
Ok, i will look into that.
I just thought, if I use your rkeyboard.zip, I will replace your finless keyboard. But it's possible I regret that after testing. So I thought maybe it's possible to go back (again) to your finless keyboard.
A very noob question: I thought my wireless keyboard is a remote controller, but apparently I'm wrong...
blinking light still blinks occassionally about evry 2 minutes looks liek might be delayed timer added
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postblinking light still blinks occassionally
JustMe
Until we get our kernel guys (which I am not) going on the sources, not much we can do here.
over its a good rom have not tested paid apps has anyone?Bugs are Sons of Glitches!
JustMe
what you trying to say new xbmc 13.2 does amlogic decodingBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postwhat you trying to say new xbmc 13.2 does amlogic decoding
There are currently 2282 users online. 1 members and 2281 guests.
