How to unbrick MK809III / MK809IV after flahing ncr19a made the device vanish??
    Originally posted by nocliptoni View Post
    Ok , i am not sure if i have tried that one,will try later when ill get back home and have time to fire up the PC .Will let you know , even if it goes south thank you for your reply it's greatly appreciated
    An other post with mediafire link for similar firmwares
    nb : i had a lot of error in find or erase nand/idb fails before having success in flash with a compatible firmware, use rkbatch tool in mask mode (blue square) and RESTORE button.
      So far same problem persists , now i am downloading the ROM of your latest post see how that goes.
Name:	ready to go.png
ID:	433764Click image for larger version
Name:	no can do.png
ID:	433765Click image for larger version
        And another no, damn what am i doing wrong?
          I got exactly the same hardware :
          Once in mask mode, if you have errors (idb failed ...) the rom is probably no fit for your hardware (i got the same issue)
          Go in mask mode (short pin) again with RKBatchTool v1.7, square must be blue, then try this one :
          cyxtech_rk31_809III_8089_140509
          you can find it here for example :
          百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。现在注册即有机会享受2T的免费存储空间
          or
          http://pan.baidu.com/share/home?uk=7...ategory/type=0
          Hi Kristoma,
          I have the same hardware as well. I thought I had a MK809IV and falshed a 4.4 kitkat rom wich is working fine other than the wifi which I absolutely need.
          After installing this kitkat rom the device is not recognised anymore by my Win 8 pc.
          Sorry for asking you all the following questions but it seems you sorted everything out.
          Can you please let me know how did you manage to get the device recognised by the PC? (if can also guide me on when connecting the USB OTG port (to pc) which assume is that one close to the sd card slot, if I need to power the device also with power supply, when and if the small recovery button has to be pressed, etc)
          Can you also please point me out where I can download the RKBatchTool v1.7?
          Regarding the ROM I downloaded that one you suggested form the chinese website.
          Thanks!!
            [ATTACH=CONFIG]6541[/ATTACH]
            i'm think that your hardware is completely ****ed up. something must be faulty
              Have any of you tried the "RESTORE" with an image that has another Boot Loader? I have fixed my MK809IV when I install other ROM that are not for it and it fixes them. I pick the Rikomagic one that its for it but it's 720p and I've been trying all kinds of ROMs and have locked up the device many times and had to RESTORE (not UPGRADE).
                Originally posted by cuboide View Post
                Hi Kristoma,
                Thanks!!
                I had a lot of trouble with this stick, so i try a lot of things but i'm pretty a newbie.
                you can download tools here for example :
                And it seems that some people have problemes with driver on Windows 8 :
                In order to make it detect, you only have to maintain 'recovery' button press, then plug OTG port to an USB port of your PC
                No power supply needed
                  Good thinking but unfortunately I am way ahead of you lol , I have tried every bootloader I could get my hands on no joy .Only thing I cannot test really is a XP machine , you don't suppose one running in virtual machine or similar would do?
                    I am using exactly that batch tool and driver ( did try the latest 3.7 as well) , I tried older versions of the batchtool too with no luck , total noob here myself nothing to be shamed of lol I cannot get out of the mask mode so I cannot enter flash mode I think , therefore the recovery / reset button thing does not do anything for me unfortunately .
                      It is not necessary to switch to flash mode, the mask mode just seems to do things in depth and is the only solution if flash mode is not avalaible
                      As deroad, I think your hardware can be defective
                        Lol , starting to get that feeling too
                          I did it! I tried with my old laptop running XP and it recognised the device immediatelly (using reset button). I installed xp driver and succesfully flashed the chinese rom (using rk batch tool 1.6).
                          The chinese rom has the wifi very very slow and the google play store is unusable due to lentness of connection.
                          I was wondering if you tried the neomode rom as at follows for MK809III or it is incompatible?
                          How I can I get the exact specs for the device? any good app to suggest?
                          Thanks a lot for your tips so far!!!!!!
                            have a look at this thread http://www.freaktab.com/showthread.p...hlight=Neomode
                            It seems that with terminal emulator app you can get the device recognised by PC. I did not try it as I had a go with XP but for you it could be an option .
                              Im not sure about the Chinese ROM being the problem , i have found WIFI with any device i have bought of CHINA (clone phones , android sticks) tend to have a weak WIFI even after flashing a custom ROM , but like i said i am no expert .I am using my new MK809III stick connected to a Powerline Ethernet socket directly connecting it to my router upstairs as the WIFI signal was too weak for watching any HD content of the Internet, works lovely now.I will carry on trying to revive my MK809IV and will report if any success , ideas and thoughts as always are more than welcome , thank you everyone for the help so far
                                Hi , sorry took so long to reply .I haven't tried terminal emulator but my problem is not device not being recognised by the PC.Problem is after the stick is recognised and enters MaskROM mode I cannot erase/flash anything
