Very new MK808B Clone, some help needed (lost the kernel file)
Re: Very new MK808B Clone, some help needed (lost the kernel file)
Originally posted by laywaste View PostIs there a custom rom designed for this version of the Mk808b?, I am currently using the stock rom.
...good luck.
Originally posted by Shomari View Post
Originally posted by credinho View PostI road his posts and I actually got the idea that he still was having some problems with the roms that he used, but my English is not the best so... Anyway, I found one solution in another topic, at least for now everything seams to be working just fine with a stock firmware,
I still want to find out if is there any custom ROM working on this model, but for now I'm just relieved to have the device working again!
Btw. Did you erase nand before experience black screen?
How to...
Originally posted by corechip View PostSetCPU does not show 1.6GHz as an option, the maximum I can set is 1.4 GHz.
Good news: I was able to restore the complete stock image, imgRePackerRK.exe v1.04 has a bug that prevented the extraction of system.img (it was always 0 bytes) however the linux version worked.
Here the stock image: https://mega.co.nz/#!iV0hgS4b!ELMBLE...HN2YwW3nnRMxjU
Now I have another problem, I wanted to use OpenVPN and this requires the tun.ko kernel module. Using the tun.ko installer app downloads a valid kernel module and even insmod works, however as soon as the openvpn app wants to create a new tun device the whole device crashes and reboots
I also tried to downloading another tun.ko file from the droidvpn tun.ko repository by using the original Build and Device identifier: http://tun.droidvpn.com/check.php?m=...device=rk30sdk this gives a different link than http://tun.droidvpn.com/check.php?m=...0615.135019+te however the files are binary equal.
So now I need the kernel source for this damn R-BOX kernel! How can I get it? Any ideas?
I got this same MK808B from **** in July. It had 4.1 and from the seller I got a 4.2 image from this link they provided:
I used RKBatchTool v1.5 to flash it but when it was about to finish I got this Download Firmware Fail message and then he thing didn't seem to work, I connected it and the blue light was on but the TV didn't receive a signal.
After a few failed tries with different ROMs I used RKBatchTool with the one here:
http://www.freaktab.com/showthread.p...lly-Working%29
It was successfuk but still no image.
How do I flash the stock ROM here? I tried with RKBatchTool but I think I have to use the tool in the zip file. What is the difference between using batchtool and rom_flash_tool? I would appreciate clear instructions and help...
JC
Thanks a lot
Thanks PPHINC for directing me here and give me the tips I needed!
I tried the 4.4.2 version in the thread in the quote, it installed 'successfully' but when connected to the TV there is no image. Can anybody suggest an improvement for the stock ROM?
The wifi is strong after fixing the wifi cable but it is till slow most of the time!
Cheers
JC
Original ROM R-Box
I just got thie ORIGINAL ROM from the **** company from which i got my "very new MK808b clone" he is the link https://app.boxcn.net/s/fauaiyhnlp10tu950pb7
wifi too slow
Hi
My wifi speed was very bad and disconnected constantly when I first got it. I read somewhere about ground shorting with.antrnna (on mk808 model with 2 antennas) so I removed the soldering from what I believe is ground. This improved signal, at least I think so, but thr speed is too slow and even more when the device is on for a.long time, I guess heating affects it.too.
any ideas how to improve speed? Signal is.ok. Maybe I shouldn't have applied that fix for MK808 with 2 antennas?
Originally posted by abraham239 View PostStill looking for a Custon ROM that will run netflix for R-boxPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1545 users online. 1 members and 1544 guests.
