*****QuickShoT v3.1*****
Quickshot 3.1
Changelog:
-Bug adjust screen size fixed, now it can be configured in setting.
-A2 remote sound will not used by default.
-Wifi hotspot bug fixed.
-libmedia.so hacked by wasser (freaktab). Now we can enjoy dolby and DTS passthrough in XBMC too. Thanks a lot to wasser for share it.
-A2 remote key mapped correctly. Thanks a lot to casadroide (androidPC.es) for it.
-New XBMCZ compilation by jmcm66 based in XBMCZ 13.1. Modded by TNT.
-New nfs and smb scripts in init.d, to mount your network points automatically in each reboot. You need to edit them to activate.
QuickShoT V3
Changelog:
- KiTKaT!!
- Custom Kernel 1080p by default
- Built from sources
- Rooted
- Busybox updated
- All the google apps up to date.
- Added init.d support
- adb by tcp ( wifi or ethernet) by default
- Nano editor added
- Tcp tweaks added
- Minix Launcher MOD by NitroTeaM
- Dolphin as default browser. We did this because is the only one that supports flash in a usable way in kitkat. Remember to turn on the plugin, is disabled by default.
- Apps Preinstalled: EsFileExplorer, Mxplayer, Dolphin, Tincore Keymapper, Reboot, xbmc gotham, adblock, terminal emulator, Sony Walkman, ehomemediacenter, flash player hacked, etc... All the apps are installed as user so you can uninstall the ones you don't like
- QuickFlasher and Keymapper from Tincore
- Support for some flymouse, f10, f10pro, i25..etc
- Setup Wizard added
- SmartTV sytle mouse pointer
- Minix Launcher modded by us
- TWRP recovery is automatically installed on first boot.
- Quickshot-Update system. This was introduced on V2 as an easy update method, you just need to copy the update files we provide under /sdcard or on your "real" sd-card and reboot.
- jcmcm66 XBMZ compiled by netguto with passtrough activates automatically and tematized by TNT.(We need a working libmedia.so yet)
- A ton of kernels, 1080p/720p with several different overclock values. Remember, Overclock can damage your system, you use this at your own risk. We do this all the time As a plus, if you flash a 720p kernel the "small icons" patch is applied automatically, and if you flash a 1080p kernel then "big icons" patch is applied. This works for both methods, quickshot-update and quickflasher.
- Some other Tweaks
- Clear ALL Button added to the tasks manager, you can see it on top right of the screen.
- xbox360 pad patch made by Casadroide from Androidpc.es
- NFS example script included under /system/etc/init.d , just edit to suit your needs and you will have your nfs or samba shares mounted every boot.
Kernel V3.1 Features:
-24Hz added if your TV support it.
-Some minor bugs Fixes.
-HDMI values adjusted.
-USB OTG port selected in host mode by default.
-RK3188T proccessors unlocked and identified in dmesg.
Kernel V3 Features:
-NTFS and ExFat support added in kernel.
-SMB and NFS support built in kernel.
-DTS and AC3 passthrough support. (Not in XBMC yet)
-Added new governors and IOSchedulers.
-Device LED working.
-You can choose between real 720p or real 1080p kernels.
-Various overclocking values: Select them using a kernel name with:
cpuxxxx: xxxx is cpu speed Ej:cpu1608 is cpu at 1608 MHz
ddrxxx: xxx is DDR speed Ej: ddr667 is DDR at 667 Mhz
gpuxxx: xxx is GPU speed, and "h" behind is that only high speed steps are enabled:
gpu600: speed values from 133MHz to 600Mhz.
gpu600h:speed values from 400MHz to 600Mhz.
gpu798: speed values from 266MHz to 798Mhz.
gpu798h:speed values from 600MHz to 798Mhz.
[COLOR=#ff0000][SIZE=4][B]Take care if you want to come back from loader 2.xx (kitkat) to Loader 1.xx (Jellybeans) You can brick your device.
See also:
Known bugs in QS3.1 (working on them):
- On some TV screens and with certain HDMI cables you can see a 1 second screen blackout in certain circunstances. (Try other HDMI cables to solve it)
- Stock Launcher bugs (we recommend to use Nova Launcher or other one):
- Launcher Bug The quick launcher icons (lower side of the screen) are not centered when using small icons on 1080p kernels
- Launcher Bug The first time you run dolphin from the quick launch icon, the shortcut jumps to desktop and you have to move it to its place again. It looks like the dolphin jumps out of the fish tank xD
Known Bugs V3:
- Static IP can't be selected using Ethernet, it cause random bootloops.
- A2 remote bug regarding the sound output, you can workaround this by using the app soundabout, you can find it on the playstore.
- A2 remote bug regarding the HOME key and the task switch key (and others) not working. Install the patch in post 2 to solve it.
- On some screens you can see a 1s blackout in certain circumstances
- in XBMC passthought is not working properly, we need a hacked libmedia.so.
-screen scale adjustament settings are non keept.
Thanks to
To MSX2 and ZX81, administrators from http://androidpc.es/
To all people here in freaktab.com.
To RKM for its colaboration.
To abdul_pt for its great TWRP
To Petrus for its reboot app
To d33 and wasser for their great help with the kernel
To Casadroide from http://androidpc.es/ por its xbox pad patch
To SoulStyle for its nfs script
To jcmcm66 for the xbmcz.
To Superatmel from the Superteam
To our betatesters:
- Casadroide from http://androidpc.es/
- Akinator from Forocoches
- Ciberus from Forocoches
- Rdsok from Freaktab
- JDFense from Freaktab
