[ROM] Quickshot 3.1 for RKM mk902
Originally posted by leolas View PostI can't test it now because I have no access to the box.
But the navigation bar must be there, it can be hidden, to show it you must click in the button, and without release move cursor up, and the bar will appear.
I know that the navigation bar must be there, the thing is that the whole home screen seems strange, its like rotated in the wrong way.
Sent from my iPhone using TapatalkFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Re: [ROM] Quickshot 3.1 for RKM mk902
Originally posted by piotr409 View PostROM works great on mk809III but can't install wifi driver for my rtl8723au Tried to install but no chance to get it to work.
Originally posted by scooter2014 View Postwaiting on updated ver with multi user support
Sent from my iPhone using TapatalkREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
CIFS not working.
First let me tell you that i love your ROM. It perfectly working.
My question is about the CIFS. I was realy looking toward this feature. But as i could read on other comments, it is not working.
When I use the terminal emulator to mount a windows share it gives me the impression that it works.
When I check the mounted folder it is empty. When I try to make the same mount again with the same credentials, it give me the message that the device is busy. Since my knowledge is little about android or linux I now seem to be stuck. The script you supplied in your ROM does give me the same result.
I installed BusyBox btw.
Can you give me a hint to solve this problem. Or is it something that can not me solved?
I appreciate any help.
HELP PLEASE!!
I just received my brand new MK902 from DX and I have a lot of troubles.
I insalled the QS 3.1 rom but i does not boot (after the boot logo it keep rebooting) and same goes for SMIC rom. Eventually I tried the official rom and it boots (but it sucks and reboots randomly).
Now either my unit is faulty or I was thinking that it has the rk3188T version (grrrrrr, I bought this model thinking there were no T version around).
Now ..my question is:
Can I install the 720p kernel from the 3.1 qs in the official rom and later install the QS rom?
Any suggestion is wellcome
Thanks a lot
Originally posted by Fitzcrraldo View PostI just received my brand new MK902 from DX and I have a lot of troubles.
Thanks a lotThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
I ve been using this room since three month ago without problems.
MODEL: THeNiTRoBoX
KERNEL: 3.0.36+
ro.build.id: KOT49H
ro.build.display.id: rk3188-eng 4.4.2 KOT49H eng.leolas.20140520.114123 test-keys
ro.build.version.release: 4.4.2
I have a MK 809 III and it works GREAT!!!
Last two weeks it wont power on every time i plug it. Sometime it starts, sometimes it wont.
So in this case I have to unplug and plug it several times till it starts. When I use the OTG port I cant get better results.
Can somebody tell me what is going on?
Thanks in advance.
Luciano
Hi.
Encouraged by PolloLoco I ve been using this room in my MK 809III 3188T stick for 8 mounths!!
This room is simply The Best.
Pros.
Almost everything works fine
Very very estable. Cant remember when it freezes or reboot by itself.
All apps works fine and I can see movies in HD (sizes larger than 6 GB)
Anttutu 25226
cons
WiFi and Bluetooth cant work together.
Cant use Skipe (usb cam not work well)
Sometimes It wont start and is neccesary to unplug and plug several times till it starts.
Well this is my way to say THANKS for your geat work.
Feel free to ask if someone needs more informarion
Regards
Luciano
There are currently 2773 users online. 5 members and 2768 guests.
