NEW- Arnova 10G2 "GingerComb" 2.2 Pro ROM - FINAL
    Originally posted by bdoggamer535 View Post
    hey finless i used supercharger and i got to 75%. then it locked up like you said it would so i used the reset pinhole and now it is stuck in reboot. how do i get out of the reboot??
    I can't remember if it's volume up or volume down (check the OP of this thread or the readme.txt file with the firmware), but if you press reset, then hold the up (or down) volume button AND press power, the unit should boot into recovery. Wipe cache, wipe dalvik, and try to reboot. If it boots, great, if not, you'll have to reset, return to recovery and restore a Nandroid.
    Asus Transformer TF300T - ROOTED, with TWRP recovery and stock Jellybean
    HTC Rezound - ROOTED with S-OFF, running stock ICS
    Android obsessed since April 29, 2010
      Good to see you still around Harold!
      Thanks for helping
        This may sound crazy, but you might try getting hold of a copy of the original firmware and flash it. See if that will re calibrate the touch screen for you. I never had this problem on my G2, but that is what fixed my G3 when I lost the touch screen.
        Does everything work right when you use a usb mouse? Have you tried?
        You might need the mouse to go into settings and run the touch screen calibration program on the original firmware. I think there's a link to it on some of the above posts.
        Others have successfully gotten touch back doing multiple flashes of Bob's ROM. I have no idea what that did, but someone reported that a while back.
        Thanks for the advice ! Never thought of using a mouse - will try that this evening, im sure ive DL the Firmware from the arnova website (Bob includes the link in the readme - is that the same?) anyone point me to a thread wich tells how to flash firmware to original Arnova?
        appreciate your help - really thought i was out of options !
          Thanks for helping
          as i was thinking of getting the windows n101 tablet, i came across a brand new tablet from a company that is slowly being noticed. its called the Idolian Studio 10 Dual Core 10" Android 4.1 Jellybean OS 10-Point Capacitive Touchscreen Tablet PC 1.6GHz CPU 1Gb DDR3 RAM 16Gb Storage Front/Rear Camera Supports G-Sensor, 3D Games, 1080p HDMI micro-SD card 3G WIFI USB
          i got it from Amazon for $228.00 i think it is a great buy. im hoping that you guys will be able to make a rom for it since your others have been brilliant. It should come in the mail in 3-5 days.
          here are the tec specs:
          CPU: Cortex A9 dual core,1.6GHz
          Operating system: Google Android 4.1, support Adobe Flash 11.0
          RAM: 1GB DDR3
          Flash Memory: NAND Flash 16GB
          Extended micro SD: Up to 32GB
          Screen Panel: 10.1" TFT digital panel
          Aspect Ratio: 16:10
          Resolution: IPS 1280*800 pixels
          Touch Screen: 10 point multi touch capacitive type
          Camera: front x 2.0M/ Rear x 2.0M
          Wireless Lan: 802.11b/g/n
          3G: External
          G-Sensor: yes
          Bluetooth: yes
          HDMI: Double frequency output
          Speakers: Built in stereo speakers 1Wx1/8?
          Micphone: Built in Micphone
          I/O interface: 1 x Earphone 3.5mm
          1 X HDMI (1080p)
          1 X Micro 5pin USB host (kayboard and Mouse supported)
          1X DC input 5V/2A
          1X Micro SD Scoket
          Supported Video Format: MKV/MPEG4/AVI/FLV/RM/RMVB/H.264 etc/Support Video decoder HD 1080P
          Supported Audio Format: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
          Supported HDMI output: yes
          Supported Image Format: jpg, bmp, png
          Document format: doc, xls, ppt, pdf, txt
          Basic applications: Browser / Music / Video Player/ Email / Gallery / Clock / Sound Recorder / Caculator / Camera / Explorer / Settings /Youtube
          Android Market: Embedded
          Instant message: MSN/QQ/Skype
          Software Supported: Google market Android Compatible Software
          Battery: 3.7V/6800mAH,Li-ion Polymer
          Product's Dimension: 257*176*10.3mm
          Enclosure: Al-Alloy enclosure
          Weight: (with battery) 585g
          Certificate: CE,FCC,RoHs
          let me know what you think. And ill fill you in on how it performs.
          kyle
          R.i.P Arnova 10 G2
          Thanks soooooo much!! You are awesome!
          Need a graphic artist for games, want a sketch, painting, pm me and we can work something out!
          FREAKTAB is FREAKIN' AMAZING!
          Kyle
            Those sound like pretty good specs...never heard of that brand.
            Our DEV's are mostly experienced with Rockchip CPU's...but have branched out as of late. I'm not sure if we can tackle it yet.
            When it arrives, find a stock firmware either from the manufacturer or provide a ROM dump and maybe one of the DEV's can do a custom ROM.
            Finless is the Chief...he can send it to a specialist.
            Randy
              Re: NEW- Arnova 10G2 "GingerComb" 2.2 Pro ROM - FINAL
              Will do (; i wish i could be off more help to create roms but sadly im not as talented as you guys are with technology!
              bdoggamer535
              Kyle
                Here is a picture of it
                Here is the website
                bdoggamer535 aka kyle
                Kyle
                  Trying to install Ubuntu on Android
                  Bob,
                  I am trying to run through this tutorial video and install Ubuntu 12.04 over this android version, but I get this message as I am going through it maybe you can patch the kernel to work with it?
                  This is the message I get in terminal when I run the Complete Linux Installer program to Start Linux:
                  Checking loop device... FOUND
                  mount: mounting /dev/block/loop255 on /data/local/mnt failed: No such device
                  Error: Unable to mount the loop device!
                  You will know which three programs to use by looking at this video tutorial and maybe you can duplicate the error that I am getting with your kernel version which is your latest one.
                  All the required files are enclosed in a link under the youtube video.
                  Kernel 2.6.32.27
                  Finless Freaktab V2.2 Pro - Final on Arnova 10 G2
                  If you can get this kernel patched and working with this ubuntu installer that would be sweet!
                  Thanks and Merry Christmas!
                  Victor
                    Bob,
                    Is this something that may be easily fixable with Gingercomb?
                    Is there like a few settings that we can adjust in the file system with terminal?
                    Or would it be a kernel issue with getting this patched to work.
                    Victor
                      Originally posted by merculiv View Post
                      Bob,
                      Kernel 2.6.32.27
                      Victor
                      Hi, I haven't tried it yet, but I'd really like to see ubuntu run on my arnova too
                      I just looked in /dev/block on my 10G2 running the 2.2Pro too, ant there seems to be only loop0 ... to loop7. So if you can edit the ubuntu installer script, try to replace loop255 with loop7.
                      Or maybe you can try in a terminal, on the 10G2 :
                      su
                      cd /dev/block
                      ln -s loop7 loop255
                      If the ln command is not found, try instead :
                      busybox ln -s loop7 loop255
                      then :
                      ls
                      and see if there is loop255 in the entries listed
                      If that's ok, try the installer again.
                        su
                        cd /dev/block
                        ln -s loop7 loop255
                        then :
                        ls
                        Ok thanks! I will give that a try in terminal. I will let you know how and if it works.
                        Victor
                          File exists
                          su
                          cd /dev/block
                          ln -s loop7 loop255
                          then :
                          ls
                          I did the process in terminal and got back.
                          link failed File exists.
                          Then is shows the files by numbers. Which are there...
                            Doing the mount
                            When the Complete Linux Installer is doing the mount this is the message.
                            Checking loop device..... FOUND
                            Error: Unable to mount the loop device:
                            Do I need to make a folder /data/local/mnt directory?
                              Hi! I need help and hope you answer me))
                              I installed (update) busybox to 1.20.2 from google play, and after than my device not shutdown correctly. Тo be more precise, Arnova 10 G2 dot'n switch off - I see a spinning cursor to infinity.
                              How to corrent this? I dot'n recovery past version busybox (1.19.).
                              Only one way to turn off the tablet - through the terminal command 'reboot -p' or hold down the on / off button over 10 sec. Thank you and sorry for my bad english.
                                you may have to reflash the rom .
                                freaktab art developer if you like my work please buy me a pepsi
