NEW- Arnova 10G2 "GingerComb" 2.2 Pro ROM - FINAL
gsteruk, don't update the binary!!!!! I need to take that out of the instructions. I stated that a few posts up by the way.
ok, i couldnt resist trying supercharger again! the only way i could avoid being stuck on bootlogo was to before installing smanager was to use the button saviour app to get the su prompt. previously because i wasnt using full screen apps to that point, i hadnt used it. every time i try it without doing this first - for some reason i was always stuck on boot. so installed the script, followed bobs steps, reboot (didnt need to pin reset, just normal power on), and it didnt take the 3 mins which is suggested, started super quick. ran the smanager script again, and was told 100% supercharged - no issues. Very odd why it wouldnt work previously, but look forward to trying it out now :-)
a few of the things ive noticed when running supercharger, first it complains that busybox is less than 1.16, but it still runs. also the message:
starting: intent {act=android.intent.action.VIEW dat=http://goo.gl/qm6yr}
Error acticity not started, unable to resolve intent {act=android.intent.action.VIEW dat=http://goo.gl/qm6yr flg=0x10000000}
other than that it runs, just the superuser headache is really a problem :-)
Are you flashing the correct ROM here? I added busybox 1.19x for sure! Seems like your flashing something different.
OK I am going to download it and check it. SOmething is a miss here.
What the heck happened
Your right.... the download is like my OLD beta version.
I somehow messed up the files on the server.......
Stay tuned. I will make a new one and update busybox since they came out with a new SU binary since I made this.
Uploading the correct ROM now. After updating SU I had to retest.
There are currently 2972 users online. 0 members and 2972 guests.
