KitKat Kernels(Build on Request)
    Originally posted by dogmangame View Post
    works fantastic rtl8188 thank you got my device up to date not being pushy is it possible to oc to 1.8ghz
    You should be able to use rkpatchomatic to overclock it.
      RTL8188 & ESP8089 kernels uploaded.
      Hi , thx for the kernele, it boots ok but unfortunately wifi doesn't work , this is the dmesg from the kernel dmsegnew.txt
        Originally posted by myzar View Post
        Hi , thx for the kernele, it boots ok but unfortunately wifi doesn't work , this is the dmesg from the kernel [ATTACH]6678[/ATTACH]
        Follow thread #1 and #61 here
        then post the ones from the kernel where wifi is working.
          ok done dmesggpio.txt
            ok done [ATTACH]6679[/ATTACH]
            Try this one
              Unfortunately still no wifi do you need a dmesg from this kernel ?
                1. Must be rooted
                2. Busybox installed.
                3. run prepare.sh
                4. run gpio_dump.sh
                gets saved in sdcard.
                Make 4 files and rename w1b1.txt, meaning w1 = wifi on, b0 = bluetooth off.
                5. run gpio-find.py or agpio.py to get another file with wifi pin.
                6. Make sure python from playstore is installed.
                Use http://apps.evozi.com/apk-downloader/ to download apps from playstore to pc to install with flash drive.
                MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                  1. Must be rooted
                  3. run prepare.sh
                  4. run gpio_dump.sh
                  http://www.mediafire.com/download/x3...9/gpio_dump.7z
                  == WiFi ==
                  (209, 'RK30_PIN1_PC1')
                  (282, 'RK30_PIN3_PD2')
                  (277, 'RK30_PIN3_PC5')
                  == Bluetooth ==
                  (241, 'RK30_PIN2_PC1')
                  (210, 'RK30_PIN1_PC2')
                  (269, 'RK30_PIN3_PB5')
                  (281, 'RK30_PIN3_PD1')
                  is that the desidered output ?
                    1. Minix X5
                    2. RK903
                    3. TV Box
                    4. RK3066
                    5. 720p Kernel
                    6. PMU ,ethernet, usb devices(gamepad,audio,camera etc) included
                    7. stock, no overclocked kernels. (CPU max 1608Mhz)
                    8. Dmesg (dmesg.txt)
                    9. Wifi GPIO Pin numbers (all 4 files (w0b0,w1b0,w0b1,w1b1) have the same GPIO output)
                    GPIO gpio1 195 rk903_26M_rts
                    GPIO gpio1 222 phy_power_en
                    GPIO gpio3 263 sdmmc-power
                    GPIO gpio3 264 mmc0-clk
                    GPIO gpio3 265 mmc0-cmd
                    GPIO gpio3 266 mmc0-data0
                    GPIO gpio3 267 mmc0-data1
                    GPIO gpio3 268 mmc0-data2
                    GPIO gpio3 269 mmc0-data3
                    GPIO gpio3 272 mmc1-cmd
                    GPIO gpio3 273 mmc1-data0
                    GPIO gpio3 274 mmc1-data1
                    GPIO gpio3 275 mmc1-data2
                    GPIO gpio3 276 mmc1-data3
                    GPIO gpio3 277 mmc1-clk
                    GPIO gpio3 278 rk903_26M_wake
                    GPIO gpio3 279 rk903_26M_poweron
                    GPIO gpio3 280 wifi_power
                    GPIO gpio3 281 rk903_26M_reset
                    GPIO gpio4 311 ?
                    GPIO gpio6 353 remotectl
                    GPIO gpio6 354 play
                    GPIO gpio6 355 usb_detect
                    GPIO gpio6 356 wm831x
                    GPIO gpio6 359 rk903_26M_wake_host
                    GPIO gpio6 360 poweronpin
                    GPIO gpio6 361 NULL
                    GPIO gpio6 363 ?
                    GPIO gpio6 364 ?
                      == WiFi ==
                      == Bluetooth ==
                      Will also try with pin RK30_PIN3_PD2 & GPIO_High/Low and different voltage later.
                        Originally posted by karel View Post
                        1. Minix X5
                        2. RK903
                        3. TV Box
                        4. RK3066
                        5. 720p Kernel
                        8. Dmesg ([ATTACH]6691[/ATTACH])
                        GPIO gpio4 311 ?
                        GPIO gpio6 354 play
                        GPIO gpio6 361 NULL
                        GPIO gpio6 363 ?
                        GPIO gpio6 364 ?
                        Can you also run GPIO_find.py?
                        You run it on the 4 w1b1 etc. files and it finds the correct one for wifi.
                        I tried to make kernels for RK903 previously, but couldn't get wifi working.
                        Maybe you can test some and see if they work later.
                          All the GPIO outputs are the same (see dmesg in previous post) therefore the python scripts can't detect the correct ones. It is kind of weird because I did switch on/off wifi and BT.
                          It does look like the MK808B is kind of the same, but you already knew that (link).
                          If you don't get it to work on your MK808B, then why would it work on the Minix X5?
                          So far I am still happy with my stable 4.2.2 rom, but if kitkat kernels, modules, system are stable I will definately switch.
                            I had success with rkpatchomatic thank you
                              Can you build realtek 8192cu driver module for 3.0.36+ kernel?
                              Sent from my GT-N5100 using Tapatalk
                                It's already included in all Jellybean and KitKat roms.
                                Or do you want a kernel with 8192cu enabled as wifi?
