KitKat Kernels(Build on Request)
    Re: KitKat Kernels(Build on Request)
    It's already included in all Jellybean and KitKat roms.
    Or do you want a kernel with 8192cu enabled as wifi?
    The module included in stock factory rom doesn't load.
    Tried different module i found here in this forum, it gets loaded, but the box rebooted itself as soon as i plugged the dongle.
    Tried compiling the driver myself, but same thing happened.
    Probably Kitkat/selinux related issue, i have no idea.
    If you can create a kernel with 8192cu as default wifi, I'd like to try.. thanks
      *Device mk809III First Gen Device board HTC-T010-V2 2013/05/23
      *WIFI AP6210
      *TVSTICK
      *RK3188FULL (not T)
      *HD KERNEL 1080P BASED ON D33 4.2 (that in my mk809III not boot Because frist generation,boot only 4.0tester no gpu no ddr overclock)
      OR KERNEL SMIC1080P (MK902- KITKAT4.4 -SMIC717394- 1080P) that in my mk809III works well but the cpu clock speed at 1.4 (also using the other 1.6 1.7 1.8 overclock kernel included in the custom rom the clock remains fixed at 1.4 ghz, this happens to me only with the kernel mk902 of smic because I think based on kernel 3188T)
      *gamepad
      *overclock cpu1,8ghz gpu798 ddr800
      *root
      *gpio_dump.txt
      *gpio_dmesg_stock.zip
      help me to have a kitkat too fast and smooth 1080p because at the time not being able to run the kernel d33 my only option is to use the kernel smic to get real 1080p!!!
      unfortunately i've no idea how to get wifi pin.
      Thanks in advance
        full hd
        Hi
        i want a fullhd kernel for oldwifi(rtl8188)
        thx.
          Originally posted by bigiuly View Post
          Hi
          thx.
          For TV Stick or Box?
            for TV Stick MK809III
            THX
              Hello, can you compile a kernel for MK908 TV Stick?
              www.sacvideolari.com www.babatorik.com
                That is RK3188 TV Stick, right?
                HD or SD kernel
                Wifi chip?
                Will make one tonight, but wifi might not work.
                Will post different kernels for most wifi chips, so people can test if it runs.
                After that, can troubleshoot the wifi GPIO pins to try to make wifi work.
                TV Sticks/Boxes with RTL8188 or other Realtek wifi have the best chance of working.
                  *WIFI AP6210
                  *TVSTICK
                  *RK3188FULL (not T)
                  *gamepad
                  *root
                  *[ATTACH]6827[/ATTACH]
                  *[ATTACH]6828[/ATTACH]
                  Thanks in advance
                  why do not you answer me?
                    HD or SD kernel
                    Wifi chip?
                    Yes it is RK3188 TV Stick, can handle HD 1080p
                    (kitkat beta rom is here but kernel have bugs;
                    -colors become broken after the shut down and re-open the hdmi source (tv)
                    -android always start with the "safe mode" (if booting while hdmi, usb hdd and remote controller plugged in)
                    -sound slider not work)
                    wifi chip is AP6210,
                    Sure i can test it,
                    Thanks.
                      1. Device name - MK 809III
                      2. Wifi chip - RTL8723
                      3. TV Stick
                      4. Platform - RK3188T
                      5. SD or HD Kernel - Either
                      Most of the other Roms will get most things right, but the WIFI, also the bluetooth, no luck with any so far. Sound just said Rockchip HDMI
                      Any help would be awesome. Thanks so much.
                        2. Wifi chip -MT5931SA
                        3. TV Stick
                        5. HD Kernel
                        Created kernel but none worked.
                        Sources here took https://github.com/Dee-UK/RK3188_KK_4.4.02_Beta.git
                        Thank you very much.
                          MK809III_RTL8188_ Stick_SD(Working)
                          MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                          please, can you make a HD version of this kernel ?
                            Originally posted by fabienk View Post
                            Yes
                            Please post in new thread
                              Thx for hd kernel RK3188-RTL 8188, but, bluetooth not working.
                              can u solve this, please
                                Please post in new thread.
                                What bluetooth chip?
                                Bluetooth is very difficult, since it also need compatible files in the rom and the right GPIO pins in the kernel.
                                Eg. MT6622 Bluetooth, only works in Mediatek Stock roms with libbtmtk.so file.
