Neomode Custom Rom MK809III MTK WiFi Version 0.9
    Hello Community,
    Here is my Rom for the owner of the MK809III with the MTK WiFi Chipset.
    This Rom is rooted and all Bloadware is removed.
    What Works?
    All should Work, but i have no MK809III with this new WiFi Chipset to Test Wifi and Bluetooth.
    What is included?
    - GAPPS
    - SuperUser
    - FreakBrowser a Web Browser from Freaktab :-)
    - XBMC 13
    - Reboot App
    - Terminal Emulator
    I also included 2 OC Kernels you find this in the Image Directory of the Rom.
    They only OC the GPU and Run fine on mine Device but no Garanty.
    Please Download and Test it, also gave Feedback please!
    Download:
    Regards
    Neomode
    tested 5 minutes
    seems all ok.
    but have one problem - shortcuts havenot names, at menu have but at main screen have not
    hot to fix it?
    p.s. wifi bt work ok
    p.p.s also in about device - it show Android 4.2.2
    It is not kitkat?
      hello
      It is a Bug from the Launcher, take a different one from Play Store.
      No it is not KitKat at the Moment. This will come Later.
      regards
      neomode
      Sent from my GT-I9305 using FreakTab v0.1.
        ok. will wait kitkat
          can someone try this Rom and told me if it works?
          MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
          Neomode
            will check one hour later
            it is with mtk chip?
              tried - not work
              after logo KITKAT stopped at android logo
                @neomode
                could you please release a OC kernel for CPU @ 1.6GHz and 1.7GHz?
                  Originally posted by declis View Post
                  @neomode
                  That could be great
                    this firmware version - cannot play videofiles from websites = have some issues with flash player and html5
                      Hi neomode
                      Can you make KitKat rom for RK3188 TV Box with Mediatek MT7601 wifi chipset and MT6622 Bluetooth?
                      These roms boot fine on my device and bluetooth is working, but not wifi
                      KitKat Kernel for my device, wifi doesn't work since it also needs
                      libhardware_legacy.so, wpa_cli, wpa_supplicant and netd in system.img compiled with the patch.
                      Mediatek MT7601 KitKat Wifi Patch
                      http://www.mediafire.com/download/hr...T7601_V2.0.rar
                      EKB311B Dmesg & GPIO Pins, Jellybean
                      http://www.mediafire.com/download/fa..._GPIO_DUMP.rar
                      My device: EKB311B
                      CPU: RK3188
                      RAM: Samsung k4b4g1646b-hcko
                      PMU: Active 8864QM
                      Audio: Rockchip RK1000-S
                      ITE IJ66121FN
                      Wifi: Mediatek MT7601
                      Bluetooth: Mediatek MT6622
                      Nand: Toshiba FK3394
                      RK3188_BOX_V2.0
                      2013-11-28
                      The GPIO for the wifi is Pin3 PA0
                      I've also sent you a PM.
                        Frame skipping
                        Neomode,
                        It working very nice on my cx 919
                        Can you add frame skipping solving kernal please ?
                        The Video is not playing smoothly
                          Thanks a lot for the files to flash the MK809 III!
                          Unfortunately now Watchever is not working anymore.
                          There is now always an error message appearing:
                          "A policy check has failed. This is usually indicates that the device has been connected to an A/V output source which the current policies or license does not allow. Please disconect your device in order to continue."
                          That is a strange message for me because the stick is as usual connected to the HDMI input port of my TV.
                          Does anybody have an idea what I need to do or is this due to the new firmware. Maybe a bug?
                          Michael
                            There is a App called HDMI Virtual Switch on Playstore.
                            This will fix the error.
                            For Recovery reboot the Stick in Recovery Mode and you have a TWRP Recovery.
                            Regards
                            Neomode
                              Thanks, that fixed the problem, but Watchever videos are not running smooth with this stick
