Neomode Custom Rom MK809III MTK WiFi Version 0.9
Originally posted by m4f1050 View PostNeo, you think you can do a ROM like NCR 3.1 with this working setup for Mediatek? Only thing I noticed not working was USB. It wasn't seeing adb or debug mode, because I was trying to root even though it has SuperUser it is not rooted.
Its easy to root this device with Kingo Abdroid ROOT.
It took me 2 mins
Regards,
Benobi
It took me 2 mins
Regards,
Benobi
Thank you a lot Neo for this rom. I can report 720p video playback is now fine with the alternate OC kernel included in the release (I have tried the kernel_cpu1608h_gpu600h_ddr400_vsfsam.img so far). 1080p is still a bit laggy, will give a try to the other OC kernel maybe.
Sound, wifi, bluetooth also ok.
Has anybody succeeded in using the TWRP partition to do a full backup? I can reboot to TWRP, but neither the keyboard nor the mouse will work there. The changelog of TWRP 2.7.0.0 for Rockchip's (here) saysCode:[...] - Mouse support via USB OTG for devices with a broken digitizer
Originally posted by zabo View PostThank you a lot Neo for this rom. I can report 720p video playback is now fine with the alternate OC kernel included in the release (I have tried the kernel_cpu1608h_gpu600h_ddr400_vsfsam.img so far). 1080p is still a bit laggy, will give a try to the other OC kernel maybe.
I've built a few random kernels with different WiFi chipsets but can't find any one to test!
Can you download this pack and report back if the kernel for your wifi is working or not. These are clocked at 1.6 GHz and are 1920x1080 for testing.
Wifi:
AP6210-alternative GPIO
ESP8089
MT5931
MK7601
RTL8723Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI've built a few random kernels with different WiFi chipsets but can't find any one to test!
Wifi:
ESP8089
MT5931
MK7601
RTL8723
EDIT: Tested (no DMESG, getting ready for work, can do more testing when I get back from work) on both this ROM, NCR MTK .9 and with NCR 3.1 but no-go on Wifi/BT. Sound still worked. Since it's one of my TV sticks in use I had to restored it back to NCR .9 with the 720p kernel it came with.Last edited by m4f1050; 25 July 2014, 11:08.
Originally posted by m4f1050 View PostWait, what kernel did you use? And do you have a Mediatek WiFi/Bluetooth combination? If you don't I would suggest you run NCR 3.1. As far as Mouse I use Microsoft 800 Keyboard/Mouse and works great both on ROM and on TWRP using the kernel that this ROM came with.
Originally posted by zabo View PostYeah, the overclocked kernel named "kernel_cpu1608h_gpu600h_ddr400_vsfsam.img", on a mk809III with Mediatek mt5931sa / mt6622n wifi/bt chips. There's another kernel named "kernel_cpu1608h_gpu600h_ddr600_vsfsam.img" in the package, but since everithing seem to work fine I'll stick to the current setup, at least unless I succeed in doing a full backup with the TWRP -which I can't until I solve the mouse problem. Speaking of which, are you using the same kernel as mine or the default "kernel.img"? Could it be that your kernel recognizes the mouse in TWRP and mine doesn't (just a guess)?
Originally posted by m4f1050 View PostIm using default kernel. Where did you find that other kernel? I can try it to see if my mouse works on TWRP.
Originally posted by zabo View PostThat's very kind of you, thanks. The other kernels are located in the same folder of the default one, just named differently (and you must instruct RKAndroidtool provided by Neomode to point at it, before flashing). The relative path once you open Neomode's archive is ..\rockdev\Image .
EDIT: I only have 1 kernel.img not the one you mentioned. Searching by that name now to see if I find it.Last edited by m4f1050; 27 July 2014, 07:10.
Wifi:
ESP8089
MT5931
MK7601
RTL8723
Thanks for your job.
I tested kernel for MTK chipsets, but WiFi and Bluetooth do not work
Regards,
Benobi
Regards,
Benobi
Last edited by d33; 28 July 2014, 15:36.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by neomode View PostKitKat Beta is out please Test it and Report back because i have no Stick with MTK Wifi.
The Kernel is 720p only at the Moment.
Regards
Ray
Download:
http://www.freak-tab.de/neomode/mk809III_mtk_1.zip
rgds,
viliam
There are currently 1844 users online. 0 members and 1844 guests.
