Neomode Custom Rom MK809III MTK WiFi Version 0.9
    Originally posted by viliamr View Post
    no matter what I try, it seems I can't root this ROM i'm trying with kingo, but it won't recognize my stick...tried with different comps, win8 and win xp too...
    is there a chance to get this ROM already rooted?
    tnx in advance
    viliamr
    Ok, i finally rooted my device. the problem was in installing ADB drivers (http://www.droidextra.org/2013/02/06...id-device.html)
    now with cifsmanager i can mount network shared folder (on my windows 8 machine), but I can't see the files in that shared folder!?!? tried mount manager too with same result. network folder is shared ok, but still emtpy when i check that folder with some file manager (tommy). wht can I do?
    rgds,
    viliam
      Had a play with both roms, 4.2 and 4.4, both run well, however wifi on 4.2 connects at 65mbps and works fine, wifi on 4.4 connects at 5mbps and can barely load websites, nevermind stream or download.
      Next, any chance of a 1080p kernel for 4.2 it looks so much better, also at stock 1.4 clocks please (mine green flickers with OC).
        No issues on 4.4 here. I have full bars, 65Mbps, but I am transmitting 1watt on my Nighthawk router, not sure if that helps or not..but I am sure it does. But I get no disconnects. Only on Bluetooth A2DP. On keyboard/mice they reconnect and keep working fine, just no audio. Using d33 kernel 4.25
          Originally posted by neomode View Post
          Hello Community,
          Here is my Rom for the owner of the MK809III with the MTK WiFi Chipset.
          This Rom is rooted and all Bloadware is removed.
          What Works?
          All should Work, but i have no MK809III with this new WiFi Chipset to Test Wifi and Bluetooth.
          What is included?
          - GAPPS
          - SuperUser
          - FreakBrowser a Web Browser from Freaktab :-)
          - XBMC 13
          - Reboot App
          - Terminal Emulator
          I also included 2 OC Kernels you find this in the Image Directory of the Rom.
          They only OC the GPU and Run fine on mine Device but no Garanty.
          Please Download and Test it, also gave Feedback please!
          Download:
          Regards
          Neomode
          I tried this ROM on my MK809III with MEDIATEK mt5931sa / mt6622n wifi/bt Chipsets.
          - Name of shortcuts are not visible, i tried diffrent launcher like S Lancher, Smart lancher, Kitkat launcher all have same problem.
          - Video quality is not very Good
          - Mouse Cursor is not moving smoothly, It lag, specially on Browser.
          Any solution to These Problems????
          http://www.mysteryofindia.com/
            PM me, I have another ROM for this stick that might work for you.
              1080p version
              KitKat Beta is out please Test it and Report back because i have no Stick with MTK Wifi.
              The Kernel is 720p only at the Moment.
              Regards
              Ray
              Download:
              Uploading right now half Hour left.
              Yay! After trying tons of Roms finally the one which is working for my UG007B with Wifi and BT! Thanks for that Any chance for a 1080p version of it?
              Thanks and best regards!
              Alex
                Regards
                Ray
                Download:
                I have tried it, WIFI works but video playback doesn't work at all . Any idea?
                  the ROM is not rooted, right? I tried many ways to root it, but without success. Any chance for rooted, Wifi-speed-improved, 1080p-version?
                  Thanks,
                  Alex
                    Help me please. It looks that everything is ok, but my TV dosn't see it, black screen....
                    20:05:34 433 Load Setting ok
                    20:05:34 473 Neomode Rom Flash Tool v1.3.7.0 Start Run
                    20:05:34 573 Scan thread:7508
                    20:05:34 583 Infothread=1900)IoControlProc-->DeviceIoControl In
                    20:05:34 583 Infothread=1900)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                    20:05:34 583 Infothread=7344)IoControlProc-->DeviceIoControl In
                    20:05:34 583 Infothread=7344)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                    20:05:34 593 Infothread=1196)IoControlProc-->DeviceIoControl In
                    20:05:34 593 Infothread=1196)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                    20:05:34 593 Infothread=7552)IoControlProc-->DeviceIoControl In
                    20:05:34 593 Infothread=7552)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                    20:05:34 593 ProcessID:5964,ThreadID:4308,RefCount:0
                    20:05:34 593 ProcessID:5964,ThreadID:7508,RefCount:0
                    20:05:34 593 ProcessID:5964,ThreadID:1900,RefCount:0
                    20:05:34 593 ProcessID:5964,ThreadID:7344,RefCount:0
                    20:05:59 358 INFO:Start to erase IDB
                    20:05:59 358 INFO:Start to lower format
                    20:06:09 359 INFO:Lower format OK
                    20:06:09 359 INFO:Erasing IDB OK
                    20:06:24 727 Loader Device Path(\\?\USB#VID_2207&PID_310B#6&2CAE7568&0&2#{a5d cbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=1216
                    20:06:24 737 INFO:Start to test device
                    20:06:24 737 INFO:Start to run
                    20:06:24 737 INFO:Test device OK
                    20:06:24 747 INFO:Start to download IDB
                    20:06:24 747 Flash Chip Information:
                    20:06:24 747 NO SIZE(MB) Manufacturer
                    20:06:24 747 ----------------------------------------------
                    20:06:24 747 0 4184MB HYNIX
                    20:06:24 757 1 4184MB HYNIX
                    20:06:24 757 ----------------------------------------------
                    20:06:24 757 INFO:BuildFlashStateMap start
                    20:06:24 757 INFO: FindAllIDB start
                    20:06:24 757 INFO:UpdateIDBData start
                    20:06:24 787 INFO:Serial Number(0):
                    20:06:24 787 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    20:06:24 787 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    20:06:24 787 INFO:UID(30):
                    20:06:24 787 00000000: 52 4F 43 4B 43 48 49 50 D0 C1 58 01 13 1B 13 24
                    20:06:24 787 00000010: 75 5F 4F 45 99 C3 1A 77 EE 1C E9 E5 E1 F6
                    20:06:24 787 INFO:BlueTooth(0):
                    20:06:24 787 INFO:Mac(0):
                    20:06:24 787 INFO:WriteXIDBlock start
                    20:06:24 787 INFO:MakeEccSpareData start
                    20:06:24 797 INFO:WriteXIDBlock start
                    20:06:24 807 INFO:Writeing the 1th ID BlockŁ¬PosŁş00008192(SEC)
                    20:06:24 807 INFO:Writing sector 00008192 ~ 00008207 ...
                    20:06:24 807 INFO:Reading sector 00008192 ~ 00008207 ...
                    20:06:24 807 INFO:check start
                    20:06:24 807 INFO:Writing sector 00008208 ~ 00008223 ...
                    20:06:24 817 INFO:Reading sector 00008208 ~ 00008223 ...
                    20:06:24 817 INFO:check start
                    20:06:24 817 INFO:Writing sector 00008224 ~ 00008239 ...
                    20:06:24 827 INFO:Reading sector 00008224 ~ 00008239 ...
                    20:06:24 827 INFO:check start
                    20:06:24 827 INFO:Writing sector 00008240 ~ 00008255 ...
                    20:06:24 827 INFO:Reading sector 00008240 ~ 00008255 ...
                    20:06:24 837 INFO:Writing sector 00008256 ~ 00008271 ...
                    20:06:24 837 INFO:Reading sector 00008256 ~ 00008271 ...
                    20:06:24 837 INFO:check start
                    20:06:24 837 INFO:Writing sector 00008272 ~ 00008287 ...
                    20:06:24 847 INFO:Reading sector 00008272 ~ 00008287 ...
                    20:06:24 847 INFO:check start
                    20:06:24 847 INFO:Writing sector 00008288 ~ 00008303 ...
                    20:06:24 847 INFO:Reading sector 00008288 ~ 00008303 ...
                    20:06:24 857 INFO:check start
                    20:06:24 857 INFO:Writing sector 00008304 ~ 00008319 ...
                    20:06:24 857 INFO:Reading sector 00008304 ~ 00008319 ...
                    20:06:24 857 INFO:Writing sector 00008320 ~ 00008335 ...
                    20:06:24 867 INFO:Reading sector 00008320 ~ 00008335 ...
                    20:06:24 867 INFO:check start
                    20:06:24 867 INFO:Writing sector 00008336 ~ 00008351 ...
                    20:06:24 877 INFO:Reading sector 00008336 ~ 00008351 ...
                    20:06:24 877 INFO:check start
                    20:06:24 877 INFO:Writing sector 00008352 ~ 00008367 ...
                    20:06:24 877 INFO:Reading sector 00008352 ~ 00008367 ...
                    20:06:24 887 INFO:check start
                    20:06:24 887 INFO:Writing sector 00008368 ~ 00008383 ...
                    20:06:24 887 INFO:Reading sector 00008368 ~ 00008383 ...
                    20:06:24 897 INFO:check start
                    20:06:24 897 INFO:Writing sector 00008384 ~ 00008399 ...
                    20:06:24 897 INFO:Reading sector 00008384 ~ 00008399 ...
                    20:06:24 907 INFO:Writing sector 00008400 ~ 00008415 ...
                    20:06:24 907 INFO:Reading sector 00008400 ~ 00008415 ...
                    20:06:24 907 INFO:check start
                    20:06:24 907 INFO:Writing sector 00008416 ~ 00008431 ...
                    20:06:24 917 INFO:Reading sector 00008416 ~ 00008431 ...
                    20:06:24 917 INFO:check start
                    20:06:24 917 INFO:Writing sector 00008432 ~ 00008447 ...
                    20:06:24 927 INFO:Reading sector 00008432 ~ 00008447 ...
                    20:06:24 927 INFO:check start
                    20:06:24 927 INFO:Writeing the 2th ID BlockŁ¬PosŁş00012288(SEC)
                    20:06:24 927 INFO:Writing sector 00012288 ~ 00012303 ...
                    20:06:24 937 INFO:Reading sector 00012288 ~ 00012303 ...
                    20:06:24 937 INFO:check start
                    20:06:24 937 INFO:Writing sector 00012304 ~ 00012319 ...
                    20:06:24 937 INFO:Reading sector 00012304 ~ 00012319 ...
                    20:06:24 947 INFO:check start
                    20:06:24 947 INFO:Writing sector 00012320 ~ 00012335 ...
                    20:06:24 947 INFO:Reading sector 00012320 ~ 00012335 ...
                    20:06:24 947 INFO:Writing sector 00012336 ~ 00012351 ...
                    20:06:24 957 INFO:Reading sector 00012336 ~ 00012351 ...
                    20:06:24 957 INFO:check start
                    20:06:24 957 INFO:Writing sector 00012352 ~ 00012367 ...
                    20:06:24 967 INFO:Reading sector 00012352 ~ 00012367 ...
                    20:06:24 967 INFO:check start
                    20:06:24 967 INFO:Writing sector 00012368 ~ 00012383 ...
                    20:06:24 967 INFO:Reading sector 00012368 ~ 00012383 ...
                    20:06:24 977 INFO:check start
                    20:06:24 977 INFO:Writing sector 00012384 ~ 00012399 ...
                    20:06:24 977 INFO:Reading sector 00012384 ~ 00012399 ...
                    20:06:24 977 INFO:Writing sector 00012400 ~ 00012415 ...
                    20:06:24 987 INFO:Reading sector 00012400 ~ 00012415 ...
                    20:06:24 987 INFO:check start
                    20:06:24 987 INFO:Writing sector 00012416 ~ 00012431 ...
                    20:06:24 997 INFO:Reading sector 00012416 ~ 00012431 ...
                    20:06:24 997 INFO:check start
                    20:06:24 997 INFO:Writing sector 00012432 ~ 00012447 ...
                    20:06:24 997 INFO:Reading sector 00012432 ~ 00012447 ...
                    20:06:25 007 INFO:check start
                    20:06:25 007 INFO:Writing sector 00012448 ~ 00012463 ...
                    20:06:25 007 INFO:Reading sector 00012448 ~ 00012463 ...
                    20:06:25 007 INFO:Writing sector 00012464 ~ 00012479 ...
                    20:06:25 017 INFO:Reading sector 00012464 ~ 00012479 ...
                    20:06:25 017 INFO:check start
                    20:06:25 017 INFO:Writing sector 00012480 ~ 00012495 ...
                    20:06:25 027 INFO:Reading sector 00012480 ~ 00012495 ...
                    20:06:25 027 INFO:check start
                    20:06:25 027 INFO:Writing sector 00012496 ~ 00012511 ...
                    20:06:25 027 INFO:Reading sector 00012496 ~ 00012511 ...
                    20:06:25 037 INFO:check start
                    20:06:25 037 INFO:Writing sector 00012512 ~ 00012527 ...
                    20:06:25 037 INFO:Reading sector 00012512 ~ 00012527 ...
                    20:06:25 037 INFO:Writing sector 00012528 ~ 00012543 ...
                    20:06:25 047 INFO:Reading sector 00012528 ~ 00012543 ...
                    20:06:25 047 INFO:check start
                    20:06:25 047 INFO:Writeing the 3th ID BlockŁ¬PosŁş00020480(SEC)
                    20:06:25 047 INFO:Writing sector 00020480 ~ 00020495 ...
                    20:06:25 057 INFO:Reading sector 00020480 ~ 00020495 ...
                    20:06:25 057 INFO:check start
                    20:06:25 057 INFO:Writing sector 00020496 ~ 00020511 ...
                    20:06:25 067 INFO:Reading sector 00020496 ~ 00020511 ...
                    20:06:25 067 INFO:check start
                    20:06:25 067 INFO:Writing sector 00020512 ~ 00020527 ...
                    20:06:25 077 INFO:Reading sector 00020512 ~ 00020527 ...
                    20:06:25 077 INFO:check start
                    20:06:25 077 INFO:Writing sector 00020528 ~ 00020543 ...
                    20:06:25 087 INFO:Reading sector 00020528 ~ 00020543 ...
                    20:06:25 087 INFO:check start
                    20:06:25 087 INFO:Writing sector 00020544 ~ 00020559 ...
                    20:06:25 087 INFO:Reading sector 00020544 ~ 00020559 ...
                    20:06:25 097 INFO:check start
                    20:06:25 097 INFO:Writing sector 00020560 ~ 00020575 ...
                    20:06:25 097 INFO:Reading sector 00020560 ~ 00020575 ...
                    20:06:25 107 INFO:check start
                    20:06:25 107 INFO:Writing sector 00020576 ~ 00020591 ...
                    20:06:25 107 INFO:Reading sector 00020576 ~ 00020591 ...
                    20:06:25 117 INFO:Writing sector 00020592 ~ 00020607 ...
                    20:06:25 117 INFO:Reading sector 00020592 ~ 00020607 ...
                    20:06:25 117 INFO:check start
                    20:06:25 117 INFO:Writing sector 00020608 ~ 00020623 ...
                    20:06:25 127 INFO:Reading sector 00020608 ~ 00020623 ...
                    20:06:25 127 INFO:check start
                    20:06:25 127 INFO:Writing sector 00020624 ~ 00020639 ...
                    20:06:25 137 INFO:Reading sector 00020624 ~ 00020639 ...
                    20:06:25 137 INFO:check start
                    20:06:25 137 INFO:Writing sector 00020640 ~ 00020655 ...
                    20:06:25 137 INFO:Reading sector 00020640 ~ 00020655 ...
                    20:06:25 147 INFO:check start
                    20:06:25 147 INFO:Writing sector 00020656 ~ 00020671 ...
                    20:06:25 147 INFO:Reading sector 00020656 ~ 00020671 ...
                    20:06:25 147 INFO:Writing sector 00020672 ~ 00020687 ...
                    20:06:25 157 INFO:Reading sector 00020672 ~ 00020687 ...
                    20:06:25 157 INFO:check start
                    20:06:25 157 INFO:Writing sector 00020688 ~ 00020703 ...
                    20:06:25 167 INFO:Reading sector 00020688 ~ 00020703 ...
                    20:06:25 167 INFO:check start
                    20:06:25 167 INFO:Writing sector 00020704 ~ 00020719 ...
                    20:06:25 167 INFO:Reading sector 00020704 ~ 00020719 ...
                    20:06:25 177 INFO:check start
                    20:06:25 177 INFO:Writing sector 00020720 ~ 00020735 ...
                    20:06:25 177 INFO:Reading sector 00020720 ~ 00020735 ...
                    20:06:25 187 INFO:Writeing the 4th ID BlockŁ¬PosŁş00024576(SEC)
                    20:06:25 187 INFO:Writing sector 00024576 ~ 00024591 ...
                    20:06:25 187 INFO:Reading sector 00024576 ~ 00024591 ...
                    20:06:25 197 INFO:check start
                    20:06:25 197 INFO:Writing sector 00024592 ~ 00024607 ...
                    20:06:25 197 INFO:Reading sector 00024592 ~ 00024607 ...
                    20:06:25 197 INFO:Writing sector 00024608 ~ 00024623 ...
                    20:06:25 207 INFO:Reading sector 00024608 ~ 00024623 ...
                    20:06:25 207 INFO:check start
                    20:06:25 207 INFO:Writing sector 00024624 ~ 00024639 ...
                    20:06:25 217 INFO:Reading sector 00024624 ~ 00024639 ...
                    20:06:25 217 INFO:check start
                    20:06:25 217 INFO:Writing sector 00024640 ~ 00024655 ...
                    20:06:25 227 INFO:Reading sector 00024640 ~ 00024655 ...
                    20:06:25 227 INFO:check start
                    20:06:25 227 INFO:Writing sector 00024656 ~ 00024671 ...
                    20:06:25 227 INFO:Reading sector 00024656 ~ 00024671 ...
                    20:06:25 237 INFO:check start
                    20:06:25 237 INFO:Writing sector 00024672 ~ 00024687 ...
                    20:06:25 237 INFO:Reading sector 00024672 ~ 00024687 ...
                    20:06:25 237 INFO:Writing sector 00024688 ~ 00024703 ...
                    20:06:25 247 INFO:Reading sector 00024688 ~ 00024703 ...
                    20:06:25 247 INFO:check start
                    20:06:25 247 INFO:Writing sector 00024704 ~ 00024719 ...
                    20:06:25 257 INFO:Reading sector 00024704 ~ 00024719 ...
                    20:06:25 257 INFO:check start
                    20:06:25 257 INFO:Writing sector 00024720 ~ 00024735 ...
                    20:06:25 257 INFO:Reading sector 00024720 ~ 00024735 ...
                    20:06:25 267 INFO:check start
                    20:06:25 267 INFO:Writing sector 00024736 ~ 00024751 ...
                    20:06:25 267 INFO:Reading sector 00024736 ~ 00024751 ...
                    20:06:25 267 INFO:Writing sector 00024752 ~ 00024767 ...
                    20:06:25 277 INFO:Reading sector 00024752 ~ 00024767 ...
                    20:06:25 277 INFO:check start
                    20:06:25 277 INFO:Writing sector 00024768 ~ 00024783 ...
                    20:06:25 287 INFO:Reading sector 00024768 ~ 00024783 ...
                    20:06:25 287 INFO:check start
                    20:06:25 287 INFO:Writing sector 00024784 ~ 00024799 ...
                    20:06:25 297 INFO:Reading sector 00024784 ~ 00024799 ...
                    20:06:25 297 INFO:check start
                    20:06:25 297 INFO:Writing sector 00024800 ~ 00024815 ...
                    20:06:25 297 INFO:Reading sector 00024800 ~ 00024815 ...
                    20:06:25 307 INFO:check start
                    20:06:25 307 INFO:Writing sector 00024816 ~ 00024831 ...
                    20:06:25 307 INFO:Reading sector 00024816 ~ 00024831 ...
                    20:06:25 317 INFO:Writeing the 5th ID BlockŁ¬PosŁş00028672(SEC)
                    20:06:25 317 INFO:Writing sector 00028672 ~ 00028687 ...
                    20:06:25 317 INFO:Reading sector 00028672 ~ 00028687 ...
                    20:06:25 317 INFO:check start
                    20:06:25 327 INFO:Writing sector 00028688 ~ 00028703 ...
                    20:06:25 327 INFO:Reading sector 00028688 ~ 00028703 ...
                    20:06:25 327 INFO:check start
                    20:06:25 327 INFO:Writing sector 00028704 ~ 00028719 ...
                    20:06:25 337 INFO:Reading sector 00028704 ~ 00028719 ...
                    20:06:25 337 INFO:check start
                    20:06:25 337 INFO:Writing sector 00028720 ~ 00028735 ...
                    20:06:25 347 INFO:Reading sector 00028720 ~ 00028735 ...
                    20:06:25 347 INFO:check start
                    20:06:25 347 INFO:Writing sector 00028736 ~ 00028751 ...
                    20:06:25 347 INFO:Reading sector 00028736 ~ 00028751 ...
                    20:06:25 347 INFO:Writing sector 00028752 ~ 00028767 ...
                    20:06:25 357 INFO:Reading sector 00028752 ~ 00028767 ...
                    20:06:25 357 INFO:check start
                    20:06:25 357 INFO:Writing sector 00028768 ~ 00028783 ...
                    20:06:25 367 INFO:Reading sector 00028768 ~ 00028783 ...
                    20:06:25 367 INFO:check start
                    20:06:25 367 INFO:Writing sector 00028784 ~ 00028799 ...
                    20:06:25 377 INFO:Reading sector 00028784 ~ 00028799 ...
                    20:06:25 377 INFO:check start
                    20:06:25 377 INFO:Writing sector 00028800 ~ 00028815 ...
                    20:06:25 377 INFO:Reading sector 00028800 ~ 00028815 ...
                    20:06:25 387 INFO:Writing sector 00028816 ~ 00028831 ...
                    20:06:25 387 INFO:Reading sector 00028816 ~ 00028831 ...
                    20:06:25 387 INFO:check start
                    20:06:25 387 INFO:Writing sector 00028832 ~ 00028847 ...
                    20:06:25 397 INFO:Reading sector 00028832 ~ 00028847 ...
                    20:06:25 397 INFO:check start
                    20:06:25 397 INFO:Writing sector 00028848 ~ 00028863 ...
                    20:06:25 397 INFO:Reading sector 00028848 ~ 00028863 ...
                    20:06:25 407 INFO:check start
                    20:06:25 407 INFO:Writing sector 00028864 ~ 00028879 ...
                    20:06:25 407 INFO:Reading sector 00028864 ~ 00028879 ...
                    20:06:25 417 INFO:Writing sector 00028880 ~ 00028895 ...
                    20:06:25 417 INFO:Reading sector 00028880 ~ 00028895 ...
                    20:06:25 417 INFO:check start
                    20:06:25 417 INFO:Writing sector 00028896 ~ 00028911 ...
                    20:06:25 427 INFO:Reading sector 00028896 ~ 00028911 ...
                    20:06:25 427 INFO:check start
                    20:06:25 427 INFO:Writing sector 00028912 ~ 00028927 ...
                    20:06:25 437 INFO:Reading sector 00028912 ~ 00028927 ...
                    20:06:25 437 INFO:check start
                    20:06:25 437 INFO:start to erase system disk
                    20:06:25 437 INFOownload IDB OK
                    20:06:25 437 INFO:Start to reset device
                    20:06:25 437 INFO:Reset device OK
                    20:06:25 447 INFO:LoaderThread Finish
                    20:06:27 177 Image Thread Path(\\?\USB#VID_2207&PID_310B#6&2CAE7568&0&2#{a5d cbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=7964
                    20:06:27 187 INFO:Start to test device
                    20:06:27 187 INFO:Test device OK
                    20:06:27 187 INFO:Start to download file
                    20:06:27 197 INFO: Start to download files to flash,backup offset=0x20000
                    20:06:27 197 INFO:Flash Start to download file to flash
                    20:06:27 227 Info:RKA_File_Download start,file=misc,offset=0x2000
                    20:06:27 237 Info:RKA_File_Download start,file=kernel,offset=0x4000
                    20:06:28 487 Info:RKA_File_Download start,file=boot,offset=0xc000
                    20:06:28 627 Info:RKA_File_Download start,file=recovery,offset=0x14000
                    20:06:30 007 Info:RKA_File_Download start,file=system,offset=0x562000
                    20:07:31 170 INFO: Download files to flash finished,Total(533446484)B
                    20:07:31 170 INFO: Start to check data
                    20:07:31 170 INFO:Start to check download data
                    20:07:31 230 Info:RKA_File_Check start,file=misc,offset=0x2000
                    20:07:31 240 Info:RKA_File_Check start,file=kernel,offset=0x4000
                    20:07:31 793 Info:RKA_File_Check start,file=boot,offset=0xc000
                    20:07:31 860 Info:RKA_File_Check start,file=recovery,offset=0x14000
                    20:07:32 580 Info:RKA_File_Check start,file=system,offset=0x562000
                    20:08:04 359 INFOownload file OK,Elapsed(97173MS)
                    20:08:04 369 INFO:Run OK
                      guys, I believe that you know the answer, please help !
