UPDATE!
Based on below, I have also made a 2.1 GingerComb using the old 1211 release I used for my 1.5 ROM. So you have a choice on which to try. Both download links are below!
______________________________
OK folks.... with the success of my Gingercomb ROMs on the Arnova Tablets, I am now going into BETA TEST for porting Gingercomb 2.1 CWM to the Nextbook 7P.
If you don't know what "GingerComb" is, see this post. There is also a overview video I did so you can see it in action:
http://www.freaktab.com/showthread.p...OM-Version-2-0
THIS ONLY for the Nextbook 7P Serial Number YF1211
This is a full 2.1 with ClockWork recovery, semi-debloated, App Injector, etc!
Notes:
I used the latest 1211 ROM download from the nextbook site. So this should have the latest wifi fixes, etc they talk about! This is NOT the same ROM used in my 1.5 ROM. I compared the 2 and the download from Nextbook "seems" newer than what I used in 1.5. However if this ROM has a problem with wifi or others issues, I can build against what I used in my 1.5 ROM.
I will tell you something wierd! I can test the build using the 1.5 ROM base and my Arnova 10G2 kernel BUT I cannot test the latest nextbook ROM against my kernel. So for sure they changed something!
I am unsure if the battery icon in the status bar will work. I have not applied any fix yet as I am not sure it is needed. You guys will have to let me know.
This is only semi-debloated. This time I left the stock apps in like the browser, email, etc. I removed all the "add-on" apps and you can put them back along withthe Google Apps with APP injector.
PLEASE read the READ ME. You must reboot after first flash in the proper way. After reboot if you get a bunch of errors or force close issues, you rebooted too soon and will need to reflash again.
Below is my standard talk about 2.1 for all my ROMS.
__________________________________________________ ___________
PLEASE READ the README.TXT for instructions and what this ROM is about!
REMEMBER! Just like most my ROMs that have major changes to it, ERASE IDB and FLASH THE LOADER! Do this before reporting any problems! You can have screwy things happen if you do NOT erase IDB. Loader is also very important!
OK on with the ROM.
Here is the downloads:
Newer 1211 Nextbook ROM used as a base for GingerComb
ROM -> Nextbook 7P 1211 - "GingerComb" Finless 2.1a CWM - BETA 1 (240 megs)
Older 1211 Nextbook ROM used as a base for GingerComb (like my 1.5 ROM)
ROM -> Nextbook 7P 1211 - "GingerComb" Finless 2.1b CWM - BETA 1 (240 megs)
Enjoy and happy testing!
