NEW - NextBook 7P YF1211 "GingerComb" Finless 2.1 CWM
Label yf1211 masking a yf1011 in v1.4, v1.5, now 2.1
Newer #1211 ROM used as a base for Gingercomb 2.1a
fails on my yf1211; same result as with #1211 rom for Finless' 1.4 and 1.5 ( the reason not to test 2.1b).
However Finless' #1011 rom v 1.4 and 1.5 both work on my "yf1211."
On 2.1a the fails are nill wifi and volume, both deal breakers. Also, soft Next7P buttons not work. [v1.5 has both those4 and soft in status bar.]
1. Will 2.1 come out for #1011?
2. If yes, can any img files from 2.1a be used, or will it be a complete 240 mb download?
Finless, thanks for your efforts on these roms.
RobLast edited by jrm; 08-04-2012, 00:28.Rob / jrm
_________________
N7P rooted w/ Finless #1011V1.5 (was V1.4)
The #1211 worked perfect with Finless 1.5. Almost afraid to test "GingerComb 2.1", but what the hell, in the spirit of testing & progress I'll dive in. I'm testing Newer 1211 Nextbook ROM used as a base for GingerComb. Bob has earned my trust.
So far, everything seems to be working. Battery meter works fine. Will report back if I find any beta type glitches.
8-12-12
Having trouble with Wi-Fi. Keeps saying "error" when I attempt to turn it on. Tried to manually set up Wireless network to no avail.
No sound either.
Instead of stressing on this, I will now attempt to install Older 1211 Nextbook ROM used as a base for GingerComb (like my 1.5 ROM) and see if I have any better luck. If so, I can always come back and attempt to figure out why the newer ROM failed me.
(As an aside, still trying to get a Nextbook 7 SE 4.0 from Big Lots, but they carry them randomly & I have to check in every week)
Will report on installation ofOlder 1211 Nextbook ROM. Hopefully with better results.
1. Wi-Fi fired right up.
2. Audio works fine
3. Battery icon does NOT seem to be workingLast edited by ZonaMojo; 08-12-2012, 18:04.
Originally posted by c0nK3R View PostAlright after testing the 2.1b beta these are my findings.
Works correctly
-Touch screen
-wifi
-sound
-touch buttons
-flash 11 works
What doesn't work
-battery icon displays ?
-tilt controls are backwards (i have a fix for this)
-Screen orientation is off (same fix as tilt controls)
Edit build.prop and put this line in
ro.sf.hwrotation=270
______________________________________________
Ok re-installing 1.5 for a few weeks. Will be back in hospital & need a non-beta ROM. I'll be back to test this ROM...if you guys haven't perfected it by then.Last edited by ZonaMojo; 08-22-2012, 04:07.
Apps Loading wrong Orinataion
Hey Bob I'm struggling to explain myself today so bare with me
If I load an app say I'm Holding the tablet vertically with the Soft keys facing the bottom the apps load up in a one 180Degress the opposite way vertically..
I tried to edit the Build.Prop with what was posted but that just changes the the axis of the whole unit vertically standing the unit displays the Android system In wide Horizontal mode and vice averse Any Idea?
I tried this one and it works, the older one doesn't, so your serial # start at M726HC
ROM -> Nextbook 7P 1211 - "GingerComb" Finless 2.1a CWM - BETA 1 (240 megs)
Originally posted by bcthe View PostI had try, but still can't use the 7p tabelt properly
no wifi at all.
Originally posted by stevenckl View PostI tried this one and it works, the older one doesn't, so your serial # start at M726HC
and i extracted, and run RK29update.exe
unload the SDcard before insert usb cable.,
checked loader, then clear IDA,
and reflash in previous, but no lucky,
now i download again, try it same hour later,
wish success no issue.
my one start at M726HC too, i just flash 2 times today and it works
post the message and have a look
There are currently 2074 users online. 9 members and 2065 guests.
