NEW - NextBook 7P YF1211 "GingerComb" Finless 2.1 CWM
Thats odd.... FLash 11 works on Gingercomb for the Arnova's. I would have expected it to work for nextbooks too.....
1211 problems with 2.1a
I had multiple problems with the 2.1a on my nextbook7P 1211.
1. never heard sound
2. most boots the touchscreen never responded to touch.
3. the nextbook soft buttons never worked (no light up either).
4. WiFi never worked (when turn on , it would try then just say error)
5. Without touch response, I could not re-boot or power off.
6. I was confused by the CWMR (unexpected and unfamilar)
On to the 2.1b
Everything works so far. The screen orentation and tilt sensor were out of whack. The 270 degree fix helps that but then the boot animation is confused.
Thanks for your continued hard work
Hey Tomatillo does the battery update correctly on your 1211?
Hey Finless I've noticed a couple of bugs with CWM on my 0911.
The problem is when I do an advanced restore of just the system partition I get a partial root (Es File Explorer won't set up with root permissions).
To get back full root I have to clear the data of said app and erase the permissions in superuser then reboot into Recovery select Advanced options and select fix permissions this tends to fix that error.
Do others who restore just system have this problem?
Also I'm kinda lost on the battery.smali files to fix my battery problem.
Basically the 0911 & 1211 have 5 files with battery in the name, and the stock services.jar only has 4?
I've gotten two conditions with the my adjustments which are boothangs and a Red X over the battery icon?
If you can take a look here are the files for 0911, 1211, and the GingerCombs.
NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
Yuandao/Window N101T (Model 1:2nd Batch) Running Finless Bob's 1.6 Rom kernel# 26 Found Here
ZTE Score (X500) running a rooted stock rom.
I know how to fix the battery icon but I just do not have time right now.
I can tell you how to do it if you have a linux box and can mount system.img. Otherwise I will do it when I have time.
I know I have been neglecting you Nextbook guys recently but only so much time in a day. Sorry.
We had a guy here kbmcz that I was about to promote to Dev and I sure could use the help! So anyone want to help me with dev work on the Nextbooks that knows how to do the basic ROM building work... I will help you with the harder stuff.
Yeah I have linux and know how to mount system.img So can you post the instructions.
I would help with developing but I feel I'm still to rookie-ish to help as I got my 1st android device 6 weeks ago and still discovering the basics also my timetable is kinda tight right now with preparing to go to college.
If you could make a list or description of what you need done I can try to help with stuff when I have some free time, but I can't at this time commit to be a developer.NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
OK fist you ned the stock Gingerbread ROM that the battery icon updates on. Do you have that?
I need to know which ROm you have so I can tell you how do deodex the ROm or not.
Bottom line the battery icon is in services.jar. You will take any smali codes files with battery in the name from THAT services.jar and replace them in the Cube Gingercomb services.jar. Recompaile and sign services.jat and this has always fixed the battery icon for me.
Let me know if you need more details.
Alright I've already de-odexed services.jar in both the 0911 and 1211 roms. Do I have to de-odex more of the framework files to do this?
These are the files that have battery in the name. They appear the same in 0911 and 1211 roms.
From the com/server/ folder
am/BatteryStatsService.smali
BatteryService$1.smali
BatteryService$BootComplete.smali
BatteryService.smali
PowerManagerService$BatteryReceiver.smali
The GingerCombs services.jar has all the above files except for the BatteryService$BootComplete.smali is that a problem?
I did not know I had to sign services.jat though. How do I do that?
-edit-
I'm guessing you meant the services.jar file instead of .jat I'll try again tomorrow then.Last edited by c0nK3R; 27 July 2012, 08:45.NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
No you do not have to work on framework or anything. Every time I fixed this I took those battery file you list from a working ROM to the gingercomb ROM Services.jar
To sign rename it to services.apk and use a APK tool to sign it.
rstako, not sure what to say? Maybe it wont work on yours? You did flash the loader too right?
Maybe boot into CWM and try formatting cache and data only.
Battery Icon
I had a green (OK) battery from the start (before and after flashing). After last night's 10 hour power outage, the battery icon just shows a "?". However if I touch the status bar, stats pop up that include a charge level (92%). It still says 92% even though it has been plugged in for a couple hours now.
Just restarted to see if boot updated the %. Now shows 90% ??? wtf? I'm not even sure it is battery status. I shut off the wireless to see if that was what it was indicating. it still showed the same 92%.
Welllllll. I love the clean boot!!!!
I like the new "comb" UI.
Great work Bob!
Alright Thankyou Finless I'll sign the file and let you know the results.
If it works do you want me to post the file so you can bake it into your rom as I will be using the 1211 as the doner.
And Tomatillo I've Found out that the battery status does update only during boot tho. Also 94% = 100% battery charge on mine.
Originally posted by Finless View Postrstako, not sure what to say? Maybe it wont work on yours? You did flash the loader too right?
I used the default setting and haven't checked the "flash loader" option.
I reflash again and it works perfectly now. Thank you! Bravo!
Rstako
Yeah I had no luck in fixing the battery.
I replaces those files and got a red X on the battery indicator.
Did a couple more trials and got weird stuff like the tablet partially rebooting every 15 seconds lol.
I fear the two services.jar files are incompatible due to different versions but what do I know lol.
If you could take a look whenever you get some free time.
I'm still gonna try some stuff tho to see if I can fix it.NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
Sound and Wifi are a no-go on mine. Everything else appears to be working.
Code:07-30 17:41:48.385: D/WiFiHW18(80): ERROR: init_module return ret=-1 07-30 17:41:48.385: D/WiFiHW18(80): Unable to unload driver module "wlan": No such file or directory 07-30 17:41:48.887: E/WifiService(80): Failed to load Wi-Fi driver.
Code:07-30 17:41:21.019: D/AudioHardware(46): AudioHardware pcm playback is exiting standby. 07-30 17:41:21.019: D/AudioHardware(46): openPcmOut_l() mPcmOpenCnt: 0 07-30 17:41:21.019: E/AudioHardware(46): openPcmOut_l() cannot open pcm_out driver: cannot open device '/dev/snd/pcmC0D0p': No such file or directory
There are currently 2360 users online. 1 members and 2359 guests.
