Kit Kat 4.4.2 RK3066 (Fully Working)
    Those of you with iMito MX1/MX2, UG007II, MK809II, J21 and MK808B with MTK chipset are in luck; Kit Kat 4.4.2 is now fully functional on RK3066 for your devices.
    Overclocked Kernel - 1080p (try at your own risk - CPU 1608/GPU 400/DDR 600): https://mega.co.nz/#!6N5RVIBD!48i4hG...g85DAQ7LYSUahE
    OC Kernel - CWM flashable: http://ge.tt/8IXOyRn1/v/0?c
    Stock factory kernel is 1080p ← (click for info)
    stock speeds are CPU 1512/GPU 240/DDR 396
    ROM MIRROR (faster): https://mega.co.nz/#!6cJkWDDY!-VT74e...kqkTYcjPm_KVn4
    Linux compatible (separate .img files) use rkflashkit: https://mega.co.nz/#!mEJ21QjS!X7kAQw...aAMbf2OvZF6Dpo
    Factory download link ↓:
    CWM: Download Arctools https://mega.co.nz/#!zNpiSTZB!DIy4BR...aHVlfLfglAWA8I and select (OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2) in packages. Download and install, reboot. You must select the Oma package for full CWM compatibility.
    Users experiencing 'android is upgrading' on every reboot - click here for fix (thanks to himmon)
    Click here to Enable Location Services in ROM
    Passthrough audio - YES
    ...thanks to dfgas for confirming this ROM is Netflix HD capable. (video below)
    Includes passthrough and yes XBMC goes fullscreen 'by itself'...
    this is not a valid file
    never mind, a file appears in my download folder. it just that when i was in the rar file there was nothing showing in it. could be linux that is the issue though. will test out now
      Does wifi and bluetooth work with mk808b? Are there any problems with this rom?
        I can confirm it works on the imito mx2. working on a video right now.
        btw everything works
          Can confirm working on mk809ii MTK chipset. Rom isn't rooted, fails to root with Kingo.
          Thanks for the rom Shomari, fast and clean looking rom.
          Sent from my GT-I9300 using Tapatalk
            heres the video.
              I would suggest putting on a mirror as it will soon get flooded
                can someone pls do a quick comparison between rikomagic jb and this rom? btw.. what is the actual source of this rom? minipc forum guys?
                  There's not much to compare. The 4.4.2 rom is api level 19, very much advanced from the Jelly Bean sources.
                  It has passthrough audio, immersive mode and is just as overclock friendly as Jelly Bean. All that's missing is fully functioning Kit Kat for MK808/B.
                  The original source is a Shenzhen factory. Not my work, I would have debloated the rom and rooted.
                    thanks much ! i'll try this rom shortly
                      Rooting / CWM / Mirror
                      KingoRoot will root this ROM. I've confirmed root access and root apps work.
                      Mirror: https://mega.co.nz/#!6cJkWDDY!-VT74e...kqkTYcjPm_KVn4
                        towelroot maybe?
                          Originally posted by dfgas View Post
                          towelroot maybe?
                          Towel root failed. KingoRoot worked; first select unroot, the rom shows rooted by default. Then run again and select ROOT. OP updated with OC kernel and CWM info.
                            nevermind, that was a fail. lol
                              you rock
