Can you please run El Fuente: 60 MP10 or Example Short 23.976 on Netflix and report what is the maximum bit rate are you getting?
Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by himmon View PostWith original stock kernel 9734, although low, rom is much quicker with everything for me than 4.2.2. Video playback is super smooth with Netflix, Hulu Plus, Showbox, BBC iplayer etc. Can't seem to get xfinity TV Go to work though. CA certificate issue.
With some more tweaking this ROM can match the benchmark scores of my MK808B. And I agree the overall 'feel' and 'smoothness' of this ROM is superb in comparison to even the highest overclocked 4.2 ROMs. XBMC performs very well indeed.
1080P Kernel
Anybody notice the video.use.overlay=1 line in the build.prop?
It seems the stock kernel is a 1080P kernel.
It can be confirmed by setting screen density to 240 and changing the video overlay setting to 0.
ro.sf.lcd_density=240
video.use.overlay=0
Makes sense now because ~2600-2700 is the antutu 3D score I get on my MK808B 4.2 with a 1080P kernel and that's what I get with this ROM on '720'; instead of ~2900 which is what I get with an actual 720P kernel.Last edited by Shomari; 03 July 2014, 05:42.
Re: Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by Shomari View PostHave you guys having trouble with wifi speed tried turning off the energy saving wifi settings in wifi>advanced?
I get speeds as fast the chip can handle and I haven't modded anything. Tried two routers same result. OC kernel but that shouldn't make too much of a difference re: link/throughput.
Unstable on MK809II
Hey guys, I've tested this rom on a MK809II and everything worked fine as it was powered by my laptop, but when i've chage the cable to original power supply, it doesn't load, just shows the first splash, then the animated circles then goes to black and off...
I've connect again to flash the OC Kernel, but keep the same...
Any thoughts??
Cheers and thanks!
Originally posted by gatorojo View PostHey guys, I've tested this rom on a MK809II and everything worked fine as it was powered by my laptop, but when i've chage the cable to original power supply, it doesn't load, just shows the first splash, then the animated circles then goes to black and off...
Any thoughts??
Cheers and thanks!
I have a 3.5A power supply running mine.
Originally posted by Shomari View PostSounds like a power supply issue. Have you tried again with the laptop that originally allowed the device to work properly? If you go back to the laptop and everything works then it's surely a power issue.
Maybe its something else.. I'll try to figure out
Originally posted by gatorojo View PostThanks for replying. My supply its a 1A while USB gives 0,5A so it is strange and this only happend with this ROM.
Your USB is likely giving out much more juice than that. In fact, I always do my testing of OC kernels connected to PC because it gives the most consistent, sufficient juice/current.
You'd be surprised just how crappy typical cheap power supplies commonly used with tv sticks are compared to a good/moderately decent PC power supply.
Those who have Netflix please test "El Fuente: 60 MP10" or "Example Short 23.976" and report what is the maximum bit rate are you getting(please also mention if you are on overlocked kernel or stock kernel)? I am trying to figure out if Netlifx HD is possible with this ROM and only bitrate test can confirm it.~Gopichand Pai
Originally posted by gopichandpai View PostThose who have Netflix please test "El Fuente: 60 MP10" or "Example Short 23.976" and report what is the maximum bit rate are you getting(please also mention if you are on overlocked kernel or stock kernel)? I am trying to figure out if Netlifx HD is possible with this ROM and only bitrate test can confirm it.
Other than that you may just have to wait for another user to confirm as you'd like or download the ROM and test yourself, if possible.
Originally posted by dathihi View PostThank you for this terrific ROM.
Could you please tell me what Linux compatible (separate .img files) use rkflashkit: mean ? Diffirent between stock rom with linux compatible rom ?
info: http://www.cnx-software.com/2013/11/...ware-in-linux/
There are currently 3503 users online. 3 members and 3500 guests.
