Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by Shomari View PostI keep my devices on 720p TVs so I don't use that setting, only on occasion as a test and to notify others that the kernel is indeed a true 1080p kernel.
Morning Himmon, download this file http://ge.tt/5CaW6Pn1/v/0?c and either adb push to /system/app or use a file explorer like Root Explorer to put the app in /system/app and reboot. Please report back if that enables location services on your device.
Originally posted by himmon View PostDoesnt appear to be working, copied into /system/app via ES Explorer/root explorer, rebooted and location services greyed out. Checked again in /system/app and FusedLocation.apk is in there.Last edited by Shomari; 05 July 2014, 08:16.
Originally posted by Shomari View PostDo a gesture type up swipe on the location settings tile in quick settings (upper right corner)
For anyone else, to change permissions manually on fusedlocation.apk, enable root explorer under tools in ES explorer, select FusedLocation.apk under /system/app and press more icon (bottom right hand side in ES), then select properties and next to permissions select change and tick Owner-Read and Write, Group-Read, Other-Read only. You should end up with rw- r- r- on previous screen. Switch off root explorer once you've made the changes and reboot.Last edited by himmon; 05 July 2014, 08:30.
Originally posted by himmon View PostBrilliant, working now! Well done mate, on the quick settings (Upper right hand corner swipe down), I left mouse clicked pressed down on the location icon for 3 seconds and it switched on. I ran fix permissions too and rebooted then was asked on startup to allow google access to location services. All working great, thanks alot. Google earth working perfectly.
Next I need to find a way to zoom back out on google earth
XBMC Users
XBMC users (even BeyondXBMC) go to Settings and change
[Expert level] >System>Video Output>Vertical blank sync = Disabled and check the reported fps in system info.
XBMC 14.0 Alpha shows 100 fps when idle. I'd suggest turning off vertical blank sync and leaving it off if it doesn't cause any problems, which it doesn't on this ROM.
Originally posted by Vovagr View PostBig thanks Shomari, everything works! Himmon - Setting-ACcessibility-Mouse Wheel Zoom Settings-Enable Wheel Zoom. Works if you press and turn the mouse wheel.
Originally posted by Vovagr View PostBig thanks Shomari, everything works! Himmon - Setting-ACcessibility-Mouse Wheel Zoom Settings-Enable Wheel Zoom. Works if you press and turn the mouse wheel.Originally posted by himmon View PostBrilliant, thanks for that tip. Another way I found was to double left click and swipe up to zoom out but prefer your mouse wheel scroll option.
Originally posted by mystguy View Posttried bluetooth with both files... rikomagic file broke bluetooth... 2nd file seems similar as the one on this rom
Sorry but I don't use bluetooth at all on this device so my help is a bit limited. Let me know if you're interested.
Originally posted by Shomari View PostXBMC users (even BeyondXBMC) go to Settings and change
BTW, just tried Wasser's 1.2 XBMC Gotham 13.1 and it runs perfectly. It's over in the Minix X7 thread. It's perfectly mapped for Minix A2 Airmouse if you have one. Just tried a 1080p movie streaming on navi x, runs perfectly smooth. I'm so shocked now how this $35 mk809ii stick is shaming my Minix X7 in terms of value for money and not too far of performance in playing movies.
Note, you'll need to enable mouse and tablet support in XBMC as its disabled by default annoyingly.
Originally posted by mystguy View Postsure... please share
adb push /system/lib
Originally posted by himmon View PostBTW, just tried Wasser's 1.2 XBMC Gotham 13.1 and it runs perfectly. It's over in the Minix X7 thread. It's perfectly mapped for Minix A2 Airmouse if you have one. Just tried a 1080p movie streaming on navi x, runs perfectly smooth. I'm so shocked now how this $35 mk809ii stick is shaming my Minix X7 in terms of value for money and not too far of performance in playing movies.
There are currently 2612 users online. 0 members and 2612 guests.
