Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by Shomari View PostThis ROM carries with it a minor HDMI audio bug persistent in KitKat update.
HDMI doesn't send audio to the TV when device is resumed from standby.
To solve the issue, always resume device from standby before powering on TV. Turn device on, then turn TV on.
The audio issue is caused by Rockchip's KitKat audio kernel configuration. The device expects a specific response from the HDMI sink, if it isn't found it effectively mutes the HDMI audio engine by treating the device as a DVI interface. 'rk30-hdmi: warning: EDID error, assume sink as DVI'Will try to recover now
Originally posted by HaLLoWeD View PostJust solved the prb. Somehow previously working drivers didnt worked and i've used PLT-7035 ADB Drivers after enabling USB Debug. Many thanks for your helpOriginally posted by HaLLoWeD View PostI really appreciate your help, it was hanging after a restart and never resumed. Have to power off / on again and again wasnt aware of such a bug. I faced such an audio issue and enabled passthrough only was working fine. Now just a blank screen, Wish i had read a few mins beforeWill try to recover now
After seeing posts about boot loops, I tested a stock 1.5a power supply and the device hung on reboot. My 3.5a power supply has never caused my device to freeze/lock up or reboot, even through testing and regular use of my OC kernel.
Originally posted by Shomari View PostBe sure to utilize an adequate power supply, especially if the device is hanging during reboot.
After seeing posts about boot loops, I tested a stock 1.5a power supply and the device hung on reboot. My 3.5a power supply has never caused my device to freeze/lock up or reboot, even through testing and regular use of my OC kernel.Thanks again
Originally posted by Shomari View PostTo solve the issue, always resume device from standby before powering on TV. Turn device on, then turn TV on.
Originally posted by Shomari View PostJust the kernel: http://ge.tt/6PbspOn1/v/0?c
Good luck and please report back. I still think it's power supply issues in your case but you never know, you're close.
Originally posted by optimummind View PostThank you. I'm gonna try the Ugoos 4.4.2 ROM + kernel from this ROM to see if everything will work. Will report back.
Power Supply
At my little town the only supply i've found has 5.1V 2.1A (I think is an iPad spare charger) and i was kind of worried about that 0.1 extra Volt, but the i've read this at some other forum:
USB 1 and 2 spec is 5v +- 5% which is 4.75 to 5.25v, so 5.1v is with USB specification.
After root, i can't manage to log at play store, that's weird, i think it must be location issue, so i'll try the FusedLocation.apk
Well... Later i'll give my comments.
By the way, i've couldn't manage to get debugging options, to get them you should go to: Settins->About Device and click 7 times on Build number and there you go...
Re: Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by gatorojo View PostFrom the specs of my device i've figured out that the original is 5V 2A, the guy who sold me this should've been using a spare one (5V 1A).
So, i'll try this one and give you my feedback, still after using the new tool and erase flash before upgrade the stick became a little more stable.
Originally posted by Shomari View PostThis ROM is better overall but the other has transparent bars as the low ram flag is not enforced in the build properties as it is in this one. I think location services might be enabled in the other one without modding as well.
(1) Using Batchtool v2.1, I ran first the Erase routine and flashed the Ugoos 4.4.2 update.img file. My UG007-II booted up fine. In Settings, as expected, I couldn't toggle on the WiFi. It says "Turning on WiFi" indefinitely.
I rebooted into mask mode and using Batchtools v2.1, I flashed just the kernel from your 4.4.2 ROM. Batchtools said the flash was successful but my UG007-II boot loops at the black screen with a giant green Android robot.
In addition to the kernel, am I supposed to flash something else at the same time? Like Loader or something?
(2) Using Sergio's RK3XXX Firmware tool, I built my own custom ROM. After extracting the firmware from the Ugoos 4.4.2, I replaced just the kernel with your 4.4.2 kernel.
After rebuilding the ROM and renaming the img file to update.img, I flashed the rebuilt ROM using Batchtools v2.1, again running the Erase function first.
The UG007-II just boot loops constantly into mask ROM mode.
What else can I try at this point? Does the USB Debugging option have to be on or off before each flash?
Sent from my Nexus 5 using Tapatalk
Originally posted by Shomari View PostMaybe you can try pulling the .so files for the wifi from the ROM here and placing them in the Ugoos ROM. You can use Sergio Poverony's tool for that in Windows and rebuild/flash.
Sent from my SPH-L720
Originally posted by optimummind View PostWhere are the .so files located at? I'll give it another shot.
Originally posted by Shomari View Post...swap the .ko files in /system/lib/modules - grab the rkwifi and mt5931.ko modules and put them in the other ROM. Worth a try but it's a long shot. Only seen I work maybe once
There are currently 1814 users online. 0 members and 1814 guests.
