I'm wondering if maybe I should dump my whole ROM as a custom ROM, perhaps? Quick and easy, it should perform just as it does on my stick which is used primarily for video.
Kit Kat 4.4.2 RK3066 (Fully Working)
Re: Kit Kat 4.4.2 RK3066 (Fully Working)
[QUOTE=reddragon72;204487]Originally posted by enviro8 View Post
The tool is designed for the main IMG file not the individual broken out files boot,system, etc.
have fun!!!
I am now up and running with it
Originally posted by Shomari View Post...haha - no worries. GLTools works, though. Extra 500-700pts in antutu and much smoother graphics. I'll upload the screenshots here or via pm if you'd like.
English is my biggest issue and some time I can't find appropriate words when I'm in a hurry
It would be great if you upload your dump of ROM so as to test it's performance.
I'm not a gamer and interested in perfect on-line Full HD video streaming only like youCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
[QUOTE=enviro8;205046]Originally posted by reddragon72 View Post
Thanks for your reply. After reading through the relevant posts on the matter, I found the solution was to ensure there were no spaces in the firmware name, or in the folders or in the folder paths. I am not su8re if underscore counts as a space.
Glad to here that and I learned something at the same time. I downloaded the rom from the OP in this thread so it had no spaces in it.
Right now I am on the last leg to giving out the info and that is the "move to SDcard" issue. I am totoally stumped on why the .android_secure directory is still being pointed to on the internal NAND. Other then that all apps and relevant app files are either on the 6gb internal app partition or the external sd card.
So close!
So I'm going to nit pick a little
I love benchmarks because numbers are numbers... BUT..... can you post up some FPS of some games?
Video is video and playing one format to the next can make a huge difference as well as the level of the codec encoding performed. Also not that a 25FPS video is only going to pump out 25FPS regardless of how hyped you have your card. It seems that a boost for the VPU would be needed to actually help the video stutter less so does GLtools help with that as well?
Before I drop 2.99 on and app that I could use to buy a game I like to know definitively if a booster/hack works or not and the video's I found online really don't show me much. So getting the info directly from a user of the app who knows it very well can really help
For example, the app offers the ability to downscale resolutions, compress/decompress textures, etc. along with the ability to enable or disable certain functions of the GPU, which in turn also affect gaming performance.
But again, as far as first hand experience with gaming, I don't know how it will affect the performance of this ROM - there's not a single game on my device. The gains I benefit from regarding GLTools are all GUI related, which does affect XBMC library traversal and a few other apps.
You can try the free version, or maybe bypass the app altogether. It's really not a make-it-or-break-it type of thing, but the added boost to the RK3066 platform is noticeable, even to a non-gamer like myself.
If you want a direct, immediate and measurable impact upon gaming performance - firing up some overclocked kernels would be the best bet, and then possibly use GLTools as a complement to that.
Type password to decrypt storage
i am getting "Type password to decrypt storage" on my device on starting.
i can't flash it back beacsue it stuck on this screen and windows says "Unknown device - with Windows has stopped this device because it has reported problems. (Code 43)"i tried to
1). Reset the device with a pin.
2). update the windows drivers from Rockchip Batch Tool. it says the driver are already updated
Rockchip Batch Tool and finless flash tool doesn't recognize the device.
i want to downgrade the Rom to finless 2.1 anyone had this problem before?
alonir
Originally posted by Shomari View PostFor now no. Maybe in the future someone will patch the current kernel code with the fix (it's here in the forums) or a factory update will address the issue.
Originally posted by what_ho View PostThis Rom works well with the 'Point of View' TV-HDMI-210 device (MK809II v1.1) for everything except HDMI audio. Never managed to get any sound so far. Have tried workarounds of resuming device from standby first without success. Will have to wait for kernel code fix.~Gopichand Pai
Originally posted by Shomari View PostHave you looked at dmesg? Run dmesg if you're willing and post its contents here please. (preferably as an attachment)
Please find dmesg output attached. This is KK rom + OC kernel from this thread (audio not working with stock kernel either of course)
gopichandpai -> thank you for tip about SoundAbout app, this did not make any difference unfortunately.
If you have any cables or attachments between the stick and the HDMI I'd remove or replace them and test again.
If not, try another tv/monitor. Unfortunately, the kernels for our devices running 4.4.X all have this bug but it doesn't affect all instances as severely as it does yours.
Originally posted by Shomari View PostThanks. Your device is not getting the expected edid response from your tv/monitor's HDMI sink and it's in turn treating it as a DVI and muting the audio.
There are currently 1952 users online. 3 members and 1949 guests.
