Machspeed trio droid 7c 2.3
Congrats man! Sorry I have not been on skype much. I saw your messages much later each time.
Good job man!
I am on skype... call me
bob, when loading the ext4 modules, does it matter which order I load the modules? because I'm doing this a step at a time, I wanted to find out where the error is occurring, so I added the modules, and recompiled the boot , reflashed, and then I did an lsmod and I see that the journaling is loaded, but not the ext4. if I manually load the ext4 after boot it loads fine. blah.
thanks
pat
This is the order I use them
insmod journ.ko
insmod ext41.ko
insmod rk29xxnand_ko.ko
ok, all ext4 now.
now, I was looking and saw a pic of a cube u9gt.. and it looks EXACTLY like this tablet. I mean exactly. same specs, same connectors, everything. I wonder what would happen if I were to try to flash a u9gt rom onto this?
EDIT: even the status bar is the same, it has the same volume up/down and back buttons.Last edited by hostile; 17 August 2012, 08:52.
You cannot perma brick a RK29 tablet as long as you do NOT flash the loader from another tablet. So go ahead and try it! You can always flash back to your ROM. Again do not flash the loader from the Cube.
did some testing, the u9gtS rom seemed to work except the transflash (microsd) wouldn't read right. wireless worked good, seemed nice and snappy.. that rom was kinda weird.. it apparently was built on the 2.1 sdk, it had the ics appearance (could have been the nexus launcher though) , but according to the about, it was android 2.3.1 I'll try the u9gtsa rom tomorrow, and I'll post on how that goes. if the u9gts rom will work with the microsd card I have, Ill probably try modding that rom, it was REALLY quick.Last edited by hostile; 18 August 2012, 11:57.
more info, I've installed all 3 of the cube u9 series roms, and the u9gts and the u9gtsa both work. the u9gtsa gave me a few little bits of funkyness, but nothing major. if I were a betting man, I'd say this is a u9gts the ONLY problem I've found, is that the driver for the micro sd card doesn't support more than 16gb. it won't read my 32gb card with the cube roms installed, but it will with the stock rom that it came with. how can I verify if the video hardware decoding is functional? the u9gts rom is very responsive and quick, I may try to use that to base a rom from. I notice there aren't any ICS roms for the u9gt series. that kinda sucks, as I'd love to have ICS on this thing. I may try that 2918 ICS rom on XDA and see what kind of results I get from it.
My "gingercomb" ROM for the Arnova's and Nextbook are based on the Cube ROM. However I did have to do a bit of work figuring out drivers and lib files for some hardware and taking them from the Arnova ROM and putting them into the cube rom. While I had no SD card issues like our having, I fif have to fix the camera, sound recorder, wifi, and a few other things. Sorry I do not know what lib.so file handles the SDcard. It maybe just the vold fstab that is setting that limit?
There are currently 1627 users online. 0 members and 1627 guests.
