NEW - MK918 KitKat Customrom
Kind regards Snuffy
HotLinks: MK918 Stock Rom Collection // Q7 Stock Rom Collection
Fixing the always changing MAC address issue
Originally posted by eve_Snuffy View Posthttp://www.FreakTab.com/showthread.php?t=10098
Ccompare your board with the Screenshots in this discussion thread.
How do you connect the mk918? Via AV?
This post was created with Tapatalk. Plesse excuse any spelling errors. I'll do my very besteht.
I connect via AV. No HDMI input on TV.
Well. I couldnt figure it out yet but i believe that this Rom doesnt support AV out. Can you side test it in an HDMI device if the mk918 dos work properly after flashing nepumuks custom Rom?
This post was created with Tapatalk. Plesse excuse any spelling errors. I'll do my very best.Kind regards Snuffy
Kind regards Snuffy
Originally posted by osaka86 View PostIT's the same board=> http://www.FreakTab.com/showthread.php?t=10098
i have no AV equipment, but i will try to organize an old TV and test my kernel
Originally posted by osaka86 View PostI have flashed yet but it doesnt boot-up ? I have a CRT TV and There is no image on screen.
Originally posted by eve_Snuffy View PostFlashing done. "Box is setting up, please wait..." right now (since 3-5min - i am a lil bit nervous..)
And i have to say - the whole screen output looks just now pretty much sharpend.
If this works properly (1080p Kernel + OC) i will be the happiest man on earth. In Germany. In this flat. In this room.
/E:
Nearly 18.000 Antutu Points. Great!
Sadly my Gbit/s USB Adapter won't work (just my slow 100MBit/s :X) - i ve send you an link via PN with the Linux (and Android) files to compile and integrate it - could you please be so kind?!
Now I just flashed 205j2104 oversea img rom. it's ok but antutu test slow than stock rom. In the future,would like to flash kitkat rom and waiting stable rom.
Hi dekmaidee255,
well - if your device is capable to work with the oc kernel by nepumuk you should definetly go for this rom and using the oc kernel. It's very fast and smooth. I can report that my device is not completely stable using this oc kernel (first freeze after 48h nonstop uptime).
To fix that issue nepumuk send me another 1080p kernel with a slightly lower, but more stable oc (his words). All i can say about this - i was unable to get it work till now (i will try a few things - different settings, etc.).
So all i can recommend for now: Test the 1080p OC version. If it works for you without freezes - be happy. If it wont work stable - try the normal 1080p kernel (have not tested yet). I am quite sure that this will be the solution for a fast and reliable ROM.
Otherwise you can use the 206j. I've used it for about 3 days without any breakdown or freeze. It gave me round about 15.800 antutu points (nearly 1.000 more than under 205j). Enough for 1080p + DTS. Just use MX Player and use H/W+ Decode (u need to download custom DTS Codecs due to some creepy lawyers forced MX project to remove the codecs..)
Kind regards.Kind regards Snuffy
Originally posted by philerup View PostAm I correct in assuming the OC kernels won't work on Throttled RK3188T chips?
I've got a nice issue / i am aware of it and fix it right now (waiting for amazon to deliver)
You use OC kernel by nepumuk? Your device doesn't stay stable or goes into a boot loop?
Maybe it's your power supply. I've measured it with a voltmeter and got amazing 1.2A out of it. Not the promised 2A. This is just enough to work with the stock ROM, but if you use the OC version it just crashes at random moments (managed to view several minutes 1080p for one time, another time it went into bootloop.)
So i've ordered another psu with 3A and 5V (Ampere is absolutely unimportant but DONT use more than 5V. It would burn your device.)Kind regards Snuffy
There are currently 2055 users online. 1 members and 2054 guests.
