CS918 Board CYX_CS918 V2_3 20140510 Need rom (Custom or stock)
    Originally posted by Deivs View Post
    With xbmc, check system > system info. it is your true resolution
    tnx, i will check
    other feature that i realy link from wasser rom is - 8gb in one partition. i may be how to do this in a easy way. its interesting but not a must have feature
      anybody checked, we have true 5.1 sound through spdif? I use wasser FW and there is only 2.1. i changed in output device option between rockchip-spdif and rockchip-spdif passthrough settings, doesn't matter it stay 2.1...
        yea, and other important thing in wasser FW it is not possiblility to activate developers options, so there is no way to use kingoroot or mtk droid tools software for root option repairing or so, because no way to enable usb debugging option. That is sadly
        i dont know if was my anxiety but king0root did not fully rooted in the begening. so basicaly what i did were the followin steps.+
        (andoird 4.2)
        download and run TPSarky Von Droid
        MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
        you must have enabled debug mode and connect to pc.
        the procced does reboot the device 3 times. so every time the device boots you need to enable again connect to pc.
        when finish you need to install supersu from android market
        (android 4.4)
        Perform the same steps for android 4.2 but it does not get fully rooted like su is not copied to the correct directory and super su either.
        so you need then install kingoroot http://www.kingoapp.com/
        the enable connect to pc and debug mode enable.
        that will root the device as its expected.
        i was not able to root the device only using kingoroot i did to do it like i did upper.
        probably is that the version of TPSarky Von Droid that i did use was buggy or out dated.
          Does anyone know if there is any firmware for this device which fixes the RK3188 frame skipping issues when playing videos - either stock or custom? It's so annoying that video playback is so jerky no matter what app is being used - tried a couple of official firmwares but both are the same.
          I run the device in 720P mode (TV is only 720P), it's jerky at 50/60Hz
            im using kitkat stock version but i have not noticed any frame skipping but i have not tested much.
            check this post there its a fix for frame skipping. user at your own risk
            http://www.freaktab.com/showthread.p...-rk3188-kernel!
            Android Kitkat 4.4.2 Stock rom:
            cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g.rar : http://pan.baidu.com/s/1bnB1Sf1
              I can recommend Wasser FW 1.04, its a true 1080 p FW, but I think there is 720p support also. By the way there is hard bootable problems with restarting, but if it loading, no problems at all, except no BT support. Play FullHD movies on xbmc very smooth.
              May try stock FW cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g
                Thanks for the replies, going to try official KitKat first as ideally need the device rooted to run a Samba shared drive over WLAN, struggling to get that firmware to download without corrupting though which is a pain. Will see how I get on, if not will try the Wasser ROM, don't need bluetooth at all and I suppose I could live without root if video works well - as can always pull the SD card to put it in my tablet. Will let you know how I get on - I suffer from chronic migraine so fixing jerky video playback is a biggie for me as it triggers it within minutes.
                Thanks again
                  So I finally got the Kitkat build installed, video seems silky smooth, the 4.4 kernel must have done the trick, so pleased.
                    Good news.
                    i have connected an 2.5 notebook hdd into the usb ports and it seems that it does no have enoght power to power up the hdd.
                    did some one noticed that?
                      Thanks again
                      I did suffer the same issue trying to download.
                      finaly i did isntall a download manager as: flashget and did work ok.
                        Originally posted by tatubias View Post
                        Good news.
                        nope...all my tested firmwares working with my external 2.5 HDD well, I use external disk since the first booting device, only for firmware cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g there was a bug. My hard disk has advanced function such as sleep function after inactivity, so. this firmware somtimes booting up disk for no reason and dont let it sleep anymore But that bug was only on v6 FW, no problems with wasser and others
                        My temporary overheating fix: Click image for larger version
                          Good news.
                          I also have one 2.5" HDD which needs much power, so I use an active hub...
                          RK3288 Devices
                          - Overview BOX (LINK !)
                            Now im re formatin my hdd, but is seems if i connect the drive before the cs918 boots there is no problem with the device. i will be testing this and providing udpates.
                            my second test the hdd did work well. but i was corrupted so that why im formating the hdd
                              i did trst again with my hdd formated it did corrup the hard drive again. it may be a power issue i need to change the power suply.
                                Newbie with TV boxes
                                Hello I'm new to this tv boxes an I also have this board ... I've noticed something like frame skipping and some vsync issues.
                                can anyone point me to a firmware to solve this? And the tools to do so.. I would like to backup my current firmware just in case anything goes wrong. Thanks for your help!!!!
