CS918 Board CYX_CS918 V2_3 20140510 Need rom (Custom or stock)
Re: CS918 Board CYX_CS918 V2_3 20140510 Need rom (Custom or stock)
Originally posted by Deivs View PostHi. There are some working Fw, as you asked. https://drive.google.com/folderview?...U0&usp=sharing
Originally posted by massivebanana View PostCan someone upload the "newest" 4.4.2 stock firmware for c918 V2_3. The official site is hella slowm from 0-2.3kb/s. Thanks in advance
Installing KitKat
Hi i am very new to android, i would like to have android 4.4 on my android box. I have downloaded this https://drive.google.com/file/d/0B3W...ZnQ1pidk0/view . Can someone explain me briefly or show me an tutorial to how to install a rom. I already identified my device it's the same as the photo in the first post. I also attached a photo. Right now i have android jelly bean installed.
post
Well so far the wasser firmware loads sometimes, but its stuck in a bootloop most of the time. It also laggs like hell. I've put on the official 4.4.2 and it works but its still just 720p upscaled (Youtube only on 720). Download cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g.rar from here :
HTML Code:https://drive.google.com/folderview?id=0B3Gp-ROFRZUVUUg1WDhZc3lTSU0&usp=sharing
andRockchip_Batch_Tool_v1.7-2014-12-25.zip
Connect cs918 to the pc via the OTG (mini usb - usb).
Go under USB -> Connect to pc (Tick it)
It should install some drivers.
Then go under Storage -> USB computer connection -> Mass storage (tick)
Moar drivers !
Security -> Unknown sources (tick it)
Developer option (to enable it keep pressing Build number in About device) -> USB Debugging (tick it)
Now run Rockchip batch tool and then hold the reset button (under the cs918) and power button.
The first square should change it color to green (if its pink thne press switch in the batchtool). Now choose cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g.rar and then click restore.
It should be something like that.
If you want to root it, install Kingo root on the pc, connect your device and press root (USB debugging must be on).
hi, i installed ROM cyxtech_rk31_cs918_8723_141107_4.4_8g2g but after sound not working, i use HDMI to the TV, i try change all device in Sound Device Manager (Default, Spdif Passthrough, HDMI Bitstream).
please help
EDIT: i taking it back, now its works (HDMI Bitstream) , maybe it needed reboot
Perfect ROM, quick, smooth and stable, without crash. thanks
Originally posted by eifel View Posthi, i installed ROM cyxtech_rk31_cs918_8723_141107_4.4_8g2g but after sound not working, i use HDMI to the TV, i try change all device in Sound Device Manager (Default, Spdif Passthrough, HDMI Bitstream).
please help
i am using this rom and its great ... it fixed up other roms heating issue and rom is very smooth...
only issue i have is i am having trouble rooting this rom..
i tried kingo , it says root but applications dont have root... so its getting false
does anyone have root instructions for this rom..
please help... thanks guys
Dear Community,
Can anyone please let me know how can I format the CS918 with the following information on its board
20141107
CS918 V6_6
I have the v1.7 Batch file to connect the box to PC and have also downloaded the rockchip drivers which are working perfectly.
I tried to flash the box with various firmware's but non of them worked and the box powers on but does not run anything and just turnoff by itself.
Please provide me a resolution quickly as soon as possible it's my humble request.
I tried to contact various person but none were helpful. I am also attaching herewith the photograph of the mother board.
Dear Community,
20141107
CS918 V6_6
I tried to flash the box with various firmware’s but none of them worked and the box powers on but does not run anything and just turnoff by itself.
There are currently 1644 users online. 0 members and 1644 guests.
