KitKat/Jellybean Kernels July 2014
    Getting it now... will let you know as soon as I have tried it. Thanks
    *EDIT*
    Well I downloaded the one you linked and it does not connect the wifi. Do they perhaps have other builds? I get in to the OS no problem, just the wifi is a no go. Thanks.
    *edit2*
    Getting the pan.baidu now... had luck with one of theirs for the stock ROM. Hope this one will be better. Thanks. *update* the ROM from the pan baidu site would not let me boot past the screen that just says 'android'
      Everyone
      You can also upload your extracted kernel for RK3188 TV Stick/Box, only if the rom is after 1 May 2014.
      I will then also upload all the different stock kernels to a seperate folder to help everyone.
        ...What bluetooth are you using?
        RDA 5876 ( stick: "MK809 III", wifi: RTL8188ETV )
          Open the device, look with a magnifying glass or
          Dmesg - Terminal emulater, su then dmesg, must be root with su apk installed.
          Think it might be MT6622.
          Also need GPIO pins for bluetooth.
          I uploaded a hi-resolution pictura of my stick?
          so where is bluetooth?
            we've got the same PCB, the bluetooth chip is on the other side, just under the wifi module
              Name of the BT chip?
              If someone can post a picture and dmesg with GPIO dump, it will help a lot.
                this picture it's OK?
                  gpio_dmesg_stock.txt
                  w0b0.txt
                  w0b1.txt
                  w1b0.txt
                  w1b1.txt
                  PS: i've got an error with the python script
                    [ATTACH]7030[/ATTACH]
                    [ATTACH]7031[/ATTACH]
                    [ATTACH]7032[/ATTACH]
                    [ATTACH]7033[/ATTACH]
                    [ATTACH]7034[/ATTACH]
                    Ok, I think I got the BT driver.
                    First time I see that BT. Looks like most wifi/bt is now being replaced with RTL8723 since it has built in BT and not a seperate chip anymore.
                    Will try to make some kernels later.
                    Kernels include other fixes that stock don't like better
                    -cache
                    - hdmi improvements
                    -OTG bug fixes
                    - sound fixes
                    - overclocked
                    - 720/real 1080p
                    - more filesystem support, usb ethernet devices etc.
                    Anyone willing a make a small donation if I get it working?
                      rk3188
                      gpio.zip
                      platform rk3188
                      camera
                      wifi:MT7601
                      bluetooth:MT6622
                      ethernet
                      video out, hdmi, 3 usb+1OTG, hdmi, optical out
                      1gb ram
                      BOX
                      HD
                        Originally posted by florin_m View Post
                        [ATTACH]7082[/ATTACH]
                        platform rk3188
                        camera
                        wifi:MT7601
                        bluetooth:MT6622
                        ethernet
                        1gb ram
                        BOX
                        HD
                        Hi
                        What Box do you have?
                        What firmware/kernel are you currently using.
                        My KitKat kernel only has working bluetooth MT6622 at the moment.
                          I have the full source code for the kit kat kernel for this one :P
                          Is a no name box that stands upright on a methal leg
                            PM sent
                              Thanks for your Kernels
                              MK809III_RTL8188_Stick_SD in my MK809III Stick WIFI is work! Thanks a lot! But the buletooth still not work! My Stick's BT chips is RDA5876,can you made a Kernels with this BT chips?
                                Can you please make a kitkat kernel for the MK908 v5? I've been looking every where for a working kernel but the only one I found is Beelink's buggy beta. I can't get the GPIO pins or the Dmesg today but I'll edit this post as soon as I can (probably by wednesday), don't know if you can get a head start only with this info.
                                1. MK908 V5
                                2. AP6210
                                3. TV Stick
                                4. RK3188
                                5. SD or HD Kernel - Either
                                6. It has no devices included but I'd be nice to be able to use ethernet over usb
