KitKat/Jellybean Kernels July 2014
    Hi
    Please try my 3 new MT5931 wifi & MT6622 bt test kernels.
    http://www.mediafire.com/download/xo...8m/kernel1.img
    http://www.mediafire.com/download/er...r3/kernel2.img
    http://www.mediafire.com/download/qb...gy/kernel3.img
    If they don't work, I'll remove them to not confuse people.
      hi
      Hi guys,
      Sorry for noob question,
      Guys is there any guide to root official rkm802iv 4.4.2 firmware?
      i have search google but found nothing.
      thanks
        Hi, ı need to stock kernel
        1. Andersson Ads 3.0
        2. Wifi chip :AP6330
        3. TV Stick
        4. Platform :RK3188
        5. SD or HD Kernel
        6. No gamepad,no camera etc)
        7. Any other settings.
        Help me
          mo123
          can you up existing kitkat kernel to 1080p.
          cheers
            Hello could you please compile kernel for: RK3066 & REALTEK WIFI RTL8723BS.
            I have attached my dmesg.
            dmsg.txt
              finally finished my problem, thanks
                mk908 v3
                hi can you make a kitkat kernel for the mk908 v3 ?
                  hi can you make a kitkat kernel for the h5 tv box
                    thanks for info
                      Hi mo. Reckon you could come up with something for this? Its needs a 1080p kernel and a modified libmedia.so to enable pass through
                        Hi mo123 ! your kernel (8188 wifi) will work on k-r42 (old revision) KK rom from wasser version 1.0.4 ? or do I need to provide more informations about this tv box ?
                        k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
                        rom 1.0.4 (kitkat) old revision Wasser
                          thanks for info
                            I can't find kernel called "MK809III_RTL8188_ Stick_HD"
                            Is the same as "RK3188_8188_Stick_HD"?
                            I can note that for my MK809III and NEOMODE Android 4.4.2 Kitkat:
                            1. RK3188_8188_Stick_HD - wifi works very bad, low signal and speed
                            2. RK3188_8188_box_HD - wifi works well, speed is high
                            Bluetooth not work for both,
                              Hi, I was wondering if you could make a kernel for the ugoos um2 running rk3188 ap6120 for jellybean
                              kind regards steven
                                kind regards steven
                                Here is Kitkat firmware for the UM2, it should work better than Jellybean firmware.
                                Ugoos UM2 official product page
                                I don't make such old kernels as Jellybean or Kitkat any more.
