i want to try kitkat on rk3066 device but wifi doesnt work (tried couple of kitkat roms and they all boot but none has my wifi driver)
my device uses the Realtek RTL8188CUS chipset (i think that the RTL8192CU uses the same driver too)
if you can make a kernel i would gladly test
i have the Kimdecent B13 / MK812 device with external wifi antenna
1.device - KIMDECENT B13 (somewhere it is called MK812)
2.wifi - RTL8188CUS
3.TV STICK
4.platform - RK3066
5.SD and HD (BOTH IF POSSIBLE but if not then 720p should be fine)
