Beelink S82 / Tronsmart S89/S89H / VissonTech S82 firmware
Originally posted by Gaili View PostYeah thats my problem, i can`t mount my ext sdcard anymore Is there another way?
META-INF/com/google/android/updater-script
remove:
Code:getprop("ro.product.device") == "visson_s82" || abort("This package is for \"visson_s82\" devices; this is a \"" + getprop("ro.product.device") + "\".");
Originally posted by stane1983 View Postopen visson_s82-ota-20140713.zip with archive tool and inside it edit:
remove:
Originally posted by Biatsch View Post@stane1983
Found another 2 issues
1.Bluetooth isnt working
2.1080i resolution runs slow (everything)
... 720p resolution isnt fixed in xbmc
Bluetooth and 1080i bugs I confirm.
About XBMC, here is the issue:
Oman (not sure about other firmwares) uses XBMC 14.0-ALPHA1 in combination with MX Player. When you install my firmware (without wiping data), my version of XBMC won't be installed (13.1) because newer one already exists. Solution is to uninstall MX Player and XBMC from box and install my XBMC from http://www.stane1983.com/downloads/ (XBMC tab, version for Amlogic 4.4.2). Will update first post with this info.
Playback on 720p works on my firmware with my XBMC (I tested that issue today on Omans firmware).
AW: Beelink S82 / Tronsmart S89/S89H / VissonTech S82 firmware
Originally posted by Biatsch View PostPossibly i described it wrong.... When u set 720p resolution on box 1080p playback is just a quarter in xbmc
I am familiar with bug as Oman's latest firmware also have that bug. I'm in contact with him and told him how to fix it.
Facts:
1. Helix is still alpha version
2. Using external player such as MX Player to play video content on Amlogic is pointless as we have much better solution (AMLCodec support included in XBMC already, 13.1 Gotham just needs few patches before building to work correctly on M8 Android - thats why I put that xbmc on my webpage)
Cheers
Originally posted by stane1983 View PostYou explained it right. Here is picture that shows 1080p output on 720p resolution on my firmware with my XBMC.
Facts:
Cheers
Originally posted by daniello9 View PostI also downloaded your xbmc .. works well .. thanks. I patched home.xml to get rid of that additonal query .. and I always have to remove versioncheck .. since it complains after the edit. Possibly you know how to fix that for good :-)
Originally posted by stane1983 View PostYes, actually will be fixed (removed) in next build. Will make fresh build of XBMC soon with patched Home.xml and versioncheck removed.
Just to let Stane and the rest know,if you use Stane's XBMC on 105k4 and UP it willnot show picture while streaming for example from Icefilms,1channel etc ... But only audio !!
It is basically having the same problem i mentioned here :http://www.freaktab.com/showthread.p...age-only-sound
As for the rom it self ,i flashed it ok and my box booted for the first time only into ANDROID.After that it never booted again into the OS itself ...Then again my box is also having issues with Stane'slinux and i have a strong belief that anyone using the latest S89 boxes that came out from the factory(which we know they are using different hardware) will face the same issues ... I am pretty sure that Stane must have developed his roms on an earlier model ....
There are currently 2042 users online. 5 members and 2037 guests.
