Beelink S82 / Tronsmart S89/S89H / VissonTech S82 firmware
New version
first post updated with 20140915 version.
And please, when I ask for some feedback and testing, please don't spam thread with each issue in separate post. Also, things like bluetooth keyboard and mouse are not behaving as it should means to me like signal lights on my car are not behaving as they should. Seriously, if you're reporting some issue, explain it (what is wrong behavior and what is right behavior, is that so hard?)
Cheers!
Cheers!
Mouse and Keyboard
Hello Stane.
I come from AMLINUX, and in whole XBMC UI is design to work without the mouse mode of the remote.
Then, although the mouse mode of the remote is missing, no matter.
But without it, in android a lot of function are not achievable.
Is it possible to recover it ?
For the keyboard, the lag is not only with bluetooth: with the normal keyboard (on the screen, there is also a lag (0.5 second approximately) between the remote click ( selection of the letter) and the effective mouvement on the screen.
Apart from that, I know you're not faulty, but I am disappointed that the xvid still stutter. There has been no update of the codec in this release of Amlogic.CONFIGURATION:
Hardware: TRONSMART VEGA S89
Firmware: VISSONTECH 20140915 version
XBMC: 13.2 (include in VISSONTECH ROM)
Live TV addon: PVR IPTV Simple Client simple with a Playlist.m3u
Ces control dont work
antutu score 39k antutu score 27k but stop on 73%(same like your enym8 rom)
rii mini i25 (air mouse is ok dont have a lag but keybord still have lag)all keyboards works ok with (108k4 finless rom)
stock remote i dont try i dont have a time , device dont want to shudown with press shutdown butoon on the box ,i dont test wifi,xbmc is ok
stanes eny m8 rom vs stane rom s82 no lag with mouse ,maybe wifi works bether,i will use this rom some time and i will back with impresions ,Ty stane grate work
[QUOTE=stane1983;227051]Hi,
Cheers![/QUOTE
do u can make this rom to work with wifi 8188eu ? i dont know is wifi conf is in kernel or not ,if is posible wifi drivers for that chip u put in this rom?
There are currently 2016 users online. 4 members and 2012 guests.
