Originally posted by versus4582
View Post
Just to let Stane and the rest know,if you use Stane's XBMC on 105k4 and UP it willnot show picture while streaming for example from Icefilms,1channel etc ... But only audio !!
It is basically having the same problem i mentioned here :http://www.freaktab.com/showthread.p...age-only-sound
As for the rom it self ,i flashed it ok and my box booted for the first time only into ANDROID.After that it never booted again into the OS itself ...Then again my box is also having issues with Stane'slinux and i have a strong belief that anyone using the latest S89 boxes that came out from the factory(which we know they are using different hardware) will face the same issues ... I am pretty sure that Stane must have developed his roms on an earlier model ....
