New version of the ROM, sorry a lot about the delay I had it almost ready time ago, but August is a month without school and with a lot of heat in Spain, So beach and pool time with the family is a must
In this rom I added the 108k4 updates (thanks to Oman and Beelink for them), and some new stuff in it. I tried to solve the notification sound problems and I didn't got it yet(not to have notifications sounds in this devices is a feature for me, but like some people want them I am trying to make it work) Now all Google apps can sync with the Google account, I tested the contacts, Google music, Calendar, Google drive, etc... and all seems to work ok. Multiuser is a little better implemented, Adbul_pt give me a patch for Wiimote (I cant test it) and some suggestions for the usb support of ps3 and other pads in kernel, added some remote keylayouts definitions.
Now I will release 2 versions of the rom: FULL and LITTLE, the only difference about them is the apps preinstalled with the rom:
FULL: Stane1983 XBMC; ES explorer; Terminal emulator; adaptative rotation lock; all google apps; MX player.
LITTLE: ES explorer; Terminal emulator; adaptative rotation lock.
I hope you enjoy with the new rom and I am waiting for your feedback.
Features:
- Rooted with last Supersu Version, Init.d activated, and last complete Busybox binary installed.
- Recovery with adb support and complete busybox installed.
- Stock ir remote works in recovery.
- Kernel build with NTFS (rw), HFS (Mac filesystem), NFS, CIFS support.
- XBox and PS3 Support Build in kernel.
- Multiuser& Screen lock support enabled in the SDK.
- Clear recent Task enabled in the SDK.
- Google Apps updated to last Version.
- Preinstalled Apps: Terminal Emulator; Reboot apk; Es File Explorer, Chrome, Adaptative Rotate Lock, Xbmc 13.1 (by stane1983), MX Player and youtube. (In the FULL version, in LITTLE Version only the minimum apps)
- Some tweaks and things I cant remember actually.
Changelog:
from 108K4 Official ROM->
-Add 1080P24Hz support;
-Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
-Fix issue->Power-key of Remote might lead to reboot;
-Improve small probable of blurred screen.
Updated after last version->
-Google apps. Now they must sync with your Google account. Google music plays without problem
-Support for Wiimote (I cant test it) from Abdul_pt.
-Improved multiuser. No need to restart or suspend to change user.
-Add configurations for more remote inputs: Melee f10 and f10 pro; Rii Mini i8, Hausbell mini H7, etc...
When you install this rom all the apps installed and the xbmc pluggins,etc... wil be erased So please make a backup of them before install.
Before Install any custom ROM I suggest a full nandroid backup, you can do it now with TWRP from our mate Abdul_pt I suggest you install it:
Instructions:
-Download the zip;
-copy it to a usb memory or external Microsd card;
-Boot in recovery,
-In 1.2.0 I added in the updater script some lines to erase data and Android folder in internal sdcard; but if you experiment unstability or other problems select in recovery wipe data/factory reset (it will erase your internal sdcard and apps, but it will solve a lot of problems);
-and select Install from EXT,
-select the zip file and wait until it finish,
-then select in recovery reboot.
Once the ROM is installed, after first boot it will reboot the Box to properly installation of some configurations, so wait some minutes in the welcome screen without touch anything and it will reboot automatically.
Flash every rom under your responsibility, I tested this one in my Beelink M8 round device and works fine.
Download:
FULL: http://www.freak-tab.de/leolas/beeli...d-AML_S802.zip
LITTLE: http://www.freak-tab.de/leolas/beeli...8B-Rounded.zip
[OLD] Beelink M8-S82 Round TV Box. Leolas V1.1.0
Following the suggestions of people here I added some of your recommendations, and I am working in other ones yet. The rom is compiled from 106k4 SDK sources.
Changelog:
- New kernel with ps3 and more game controllers enabled (In the previous version y forgot to add them to the definitive build, now they are included)
- Screen-lock disabled by default for those users that only use the stock remote.
- New XBMC added to the rom build by stane1983 so all credits for this XBMC are for him.
- New Screensaver wallpapers and fixed.
- Apps updated to last version and some minor tweaks and customizations.
Download Link.
v1.1.0:www.freak-tab.de/leolas/beelink/leolas-V1.1.0-Beelink-M8.zip
[OLD] Beelink M8-S82 Round TV Box. Leolas V1.0.0
I want to release my first custom ROM for the Beelink M8, It must work for Tronsmart Vega S89/S89-H and Elite, But I cant test them.
Features:
- Preinstalled Apps: Terminal Emulator; Reboot apk; Es File Explorer, Chrome, Adaptative Rotate Lock, Xbmc 13.1 (by Oman), MX Player and youtube. (Most of them like user so they can be uninstalled easy).
Download Link:V1.0.0: www.freak-tab.de/leolas/beelink/leolas_V1.0.0-Beelink-M8.zip
Known Bugs:
Waiting for your feedback
Please to feedback the problems you found, tell me what is your device and output resolution, more details, easier to reproduce and solve. Thanks a lot.
Thanks to:
- My friends and partners in the Nitro Team: Litry, Abdul_pt and Daemonium.
- Oman from Beelink, thanks a lot for your support.
- The developers here in Freaktab: Wasser, Abdul_PT, Lokie, Woomg, etc... and specially Bob Finless, he teach me some of his tweaks for this rom in his roms builds.
- stane1983 for his xbmc build.
- Like always thanks to Petrus for his reboot apk. For me is the best way to power off or reboot to loader or recovery.
- Hardwareguru and Veronica for the keyboard layouts
- And thanks to you for install the ROM and give me feedback
Leolas
