Because change the clean button (recent app) from right to left?
[ROM] Beelink M8-S82 Round TV Box. Leolas V1.2.0
Originally posted by manu81 View Postone question
Because change the clean button (recent app) from right to left?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Re: [ROM] Beelink M8-S82 Round TV Box. Leolas V1.1.0
Originally posted by leolas View Postyes it can be done, I put it in the right to make it more noticiable, but if most of you want it in the left side I can compile the SystemUI.apk again with this changed.
The rest of rom is excellent. Congratulation !!!
Originally posted by manu81 View PostPlease I like . Can you compile? Only this change?
The rest of rom is excellent. Congratulation !!!REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by riven4300 View Posthope ps3 controller works with new update soon.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by Saris View Postcan this ROM be used on Tronsmart S89 elite?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Will this firmware work on the MXIII?
can anyone tell me if the Firmware for the S82 Round is compatible with the MXIII(S82) 2GB version.Last edited by electrogeek; 07-25-2014, 11:55.
Hello Leolas,
Tested 1.1 version... Screen saver feature is back! thx.
But strange behavior... my box fall in deep sleep after 1 hour (+ ou -) (with screensaver set to 4m).
About nfs mount issue..There is a kernel patch, which could probably solve this problem:
Hey Guys, mkasick released in his thread a fix for the mounting problems in Android >= 4.2. Description of the issue: Android >= 4.2 breaks Dalvik-apps that mount file systems to be shared with other apps. This includes CifsManager, Mount...
Android 4.2 breaks Dalvik-apps that mount file systems to be shared with other apps. This includes CifsManager, Mount Manager, essentially anything that mounts cifs shares, FUSE file sytems, etc. The symptom is that the mounted contents appear...
If you can check
Thx for your job.
Originally posted by electrogeek View Postcan anyone tell me if the Firmware for the S82 Round is compatible with the MXIII(S82) 2GB version.
Originally posted by clarkss12 View PostJust installed v1.1 and location service does not appear to be working. It worked on v 1.0. Everything else working great.
EDIT: works for me, you need to activate location in settings and in google settings.
If you can check
Thx for your job.Last edited by leolas; 07-26-2014, 09:34.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Hi Leolas
I got the new rom loaded and nova locked to one screen no scrolling in this release? The stock player doesnt go full screen the icons are still visible at top of the screen? any way to get full screen in the player? (did all the standard in the player already) ps3 worked plugged in error in bluetooth wont load.
sweet update like the task bar and its very smooth.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
The stock player works for me at full screen in 1080p or 720p, can you post a picture?
Other thing, CEC works great in my old Samsung TVREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Thanks Leolas all my issues solved switched to mx player. Havent had one single crash or reboot on this ROM. Simply blown away at how well everything works. we never had this with rockchip releases.
Bluetooth issue for ps3 driver issue maybe Oman can request from Aml? Dont think it get fixed till they release fix for it.Last edited by scooter2014; 07-27-2014, 14:38.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2357 users online. 3 members and 2354 guests.
