AML8726-MX Android Box MX jaibreak
Only by opening the case and have a look at the PCB ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by TMx View Post99% of the UK sellers are selling Clone boxes its probably the Clone PCB...RK3288 Devices
Hi I recently had a problem with my mx box were I had power but me tv saying no signal , I was giving e file matricom zip file
and told to do the tooth pic method so I tried it n the no signal went n me screen white n now I'm gettin a black screen ......
if I take the sd card out n try lower it up it goes back to no signal
I was told if I keep the toth pic I. With my sd card in android man should eventually Appear with this method
but after me screen flashes white I get nothing but black screen
many help on this please thanks
Originally posted by cowley26 View PostHi I recently had a problem with my mx box were I had power but me tv saying no signal , I was giving e file matricom zip file
1. If you start your MX you get no output at TV ("No Signal ..." at TV)?
2. If you use the SD card (with 'Matricom G-Box Midnight MX2 1.15+') and toothpick at AV you get first a white screen at TV for a moment and after a moment a black screen?RK3288 Devices
Originally posted by no_spam_for_me View PostOnly to check if I understand it correctly:
Originally posted by cowley26 View PostYes mate that's what is happening exactly mate
Because the flashing need at less 5 minutes maybe give the process 10-15 minutes at black screen before you unplug the PSU (and don't release the reset before e.g. 1 minute)...RK3288 Devices
RK3288 Devices
That happened to my boxes few times , Forget the Blank screen and no signal Keep pushing reset button with a toothpick about a minute...
leave the box alone and check if the FW installed about an half an hour time...
Despite there was no signal in the beginning My boxes turned back to life by this way.
good Luck
There are currently 3303 users online. 0 members and 3303 guests.
