MX3 BOX WITH AM LOGIC S802.
    today has been released a new firmware
    http://www.bee-link.com/en/article.php?id=134
    Date:2014.08.02
    Firmware:M82_108k4_1gddr_rtl8188
    Model:MXIII 1G/8G
    base:M82_107k4_1gddr_rtl8188
    Remark:
    1.Add 1080P24Hz support;
    2.Support for NTFS/CIFS; --Offered by wasser
    3.Change Input method to Latin,and remote can use;
    4.Update Play Store;
    5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
    6.Support for Xbox/PS3; --Offered by Bob
    7.Change method of Root access; --Offered by leolas
    8.Add kill-recent-task function; --Offered by daemonium
    9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
    10.Add remote function in Recovery Mode;--THX leolas
    11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
    12.Fix issue->Power-key of Remote might lead to reboot;
    13.Improve small probable of blurred screen.
      the s802 square m8 is cheaper with more components
      It is not cheaper ...Maybe if you have a link that states the M8 square less than 69 dollars please share with us instead of calling geekbuying liars please!!!!
        I think there are many dealers discounting the M8 to clear out stock. The cost of the M8 and MXiii 2GB are very similar. At $69 someone is only making a few $ per unit.
            do your own homework my friend and you will see. and first of all geekbuying is reseller he needs to make his cut too.
            JustMe
            Bugs are Sons of Glitches!
            JustMe
              between $68 to 73.00 depending on qty mxIII.
              JustMe
              JustMe
                JustMe
                whith shipping?i see 2gb version mxiii for 82-96usd and m8 for 85-103usd ,if u have price between 68-73 for mx3 and m8 plz share.sry on my bad eng
                  I've just purchased one of these boxes of **** in the UK and so far so good.
                  I Havnt really messed around with roms or firmware as I don't know how to install them.
                  If some one could point me in the right direction that would be great. What's this Finless rom I've read about? Is it worth installing it and also the updated firmware. I've seen that on the official website but I don't know how to install it.
                  Anyway. All works out of the box. Mainly purchased it for Xbmc. It came with 14 alpha installed but I do on removed it and put on Gotham 13.1 it works fine. No problems so far.
                  Added a few games and apps on it too. Can someone recommend a good cheap game controller so I can play Android games on it please.
                    He was referring to the cost..not retail. My cost is $55 for the 1GB and $65 for the 2GB MXiii.
                      so have you got Mx3 in hand if so could you please share your thoughts compare to other boxes you got...
                      Thanx
                        Being shipped to me now. Should have in 5 days or so.
                          Keep us updated Pls
                            Originally posted by mattyspurs76 View Post
                            ... I Havnt really messed around with roms or firmware as I don't know how to install them.
                            If some one could point me in the right direction that would be great. What's this Finless rom I've read about? Is it worth installing it and also the updated firmware. I've seen that on the official website but I don't know how to install it. ...
                            I think there doesn't exit any custom rom yet (at the moment only for round ones and another kind of square one)...
                            (Finless is one of the guys how dev/mod custom rom)
                            RK3288 Devices
                            - Overview BOX (LINK !)
                              Originally posted by TMx View Post
                              Keep us updated Pls
                              +1
                              specially 1GB version ...
                              and maybe sometimes stane will port his XBMC Linux to the 1GB version ...
                              RK3288 Devices
                                Originally posted by no_spam_for_me View Post
                                +1
                                you lost all s89 FW support +1gb ram + 5ghz wifi for $15 ! I'm sure he will port it to 2gb box cos He already port it to M8 square box and the only difference is Nand flash chips...
