TWRP for Amlogic devices.
    I have an M8N S802 square box stuck on Kitkat and have tried every TWRP image in the downloads section but nothing works! Has anyone any experience of getting TWRP to install on this device? Is there an image that works?
    Update: I've found M8N specific versions of TWRP on this forum TWRP_2.8.5.0_M8N.img and TWRP_2.8.7.0_M8N.img but they don't work either. Not sure what I'm doing wrong!
    Sorted! Just tried a different SD card - a slower one with smaller capacity and the TWRP_2.8.7.0_M8N.img worked a treat!
      I apologize if it's already asked before: Which version if any would work on Minix U9-H running Android 7.1.2 (Android TV Version)?
        Originally posted by abdul_pt View Post
        Team Win Recovery Project 2.7, or twrp2 for short, is a custom recovery built with ease of use and customization in mind. We started from the ground up by taking AOSP recovery and loading it with the standard recovery options, then added a lot of our own features. It’s a fully touch driven user interface – no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
        With an assist from Guest, Guest has now built TWRP 3.1.0-0 for the following Amlogic reference boards:
        q201: CLICK TO DOWNLOAD
        p212: CLICK TO DOWNLOAD
        p200/p200_2G: CLICK TO DOWNLOAD
        And for those brave souls who want to make changes or build for other Amlogic devices, the source is provided on GitHub here:
        https://github.com/Magendanz/android_device_amlogic
        If my Amlogic reference board box is p281 which should I use? I am out of luck if my box is based on S905W????
        • Guest's Avatar
          Guest commented
          Editing a comment
          I've been able to use the TWRP builds for p212 (or p21x) on p281 reference boards.
        my friends my device is magicsee n5.twrp download which???
          Search in GOO.. for x96miniTWRP311.zip
            Isn't he looking for a bootable recovery.img???
            I am looking for bootble recovery.img for reference board p281 as well since universal vitmod cant be launched from stock recovery...
              I manged to install TWRP 3.2.1-0 on box with 711_NHG47L_2017103112113 rom.
              But there is a problem with compression of big partitions (1GB and bigger) while the backup procedure.
              Here is a direct error message.
              createTarFork() process ended with ERROR: 255
              Backup Failed
              Can you fix it?
              Here the excerpt from the log:
              Starting TWRP 3.2.1-0-2af13795-dirty on Thu Jan 1 00:00:09 2015
              (pid 4049)
              I:=> product model: 'q20x'
              I:=> using device id: 'q20x'
              TW_NO_REBOOT_BOOTLOADER := true
              RECOVERY_SDCARD_ON_DATA := true
              TW_NO_BATT_PERCENT := true
              I:Calculating backup details...
              * Total number of partitions to back up: 1
              * Total size of all data: 1494MB
              * Available space: 19514MB
              [BACKUP STARTED]
              * Backup Folder: /usb-otg/TWRP/BACKUPS/q20x/2015-01-01--01-03-58_KIII_PRO-userdebug_711_NHG47L_2017103112113
              Backing up System...
              I:Creating backup...
              I:Creating tar file '/usb-otg/TWRP/BACKUPS/q20x/2015-01-01--01-03-58_KIII_PRO-userdebug_711_NHG47L_2017103112113/system.ext4.win'
              I:Using compression...
              I:addFile '/system/app' including root: 0
              ==> set selinux context: ubject_r:system_file:s0
              I:addFile '/system/app/AppInstaller' including root: 0
              I:addFile '/system/app/AppInstaller/AppInstaller.apk' including root: 0
              I:Error adding file '/system/app/AppInstaller/AppInstaller.apk' to '/usb-otg/TWRP/BACKUPS/q20x/2015-01-01--01-03-58_KIII_PRO-userdebug_711_NHG47L_2017103112113/system.ext4.win'
              Error creating backup.
              I:ERROR tarList for thread ID 0
              I:InfoManager saving '/usb-otg/TWRP/BACKUPS/q20x/2015-01-01--01-03-58_KIII_PRO-userdebug_711_NHG47L_2017103112113/system.info'
              Backup Failed. Cleaning Backup Folder.
              I:Copying file /tmp/recovery.log to /usb-otg/TWRP/BACKUPS/q20x/2015-01-01--01-03-58_KIII_PRO-userdebug_711_NHG47L_2017103112113/recovery.log
                Do we have any news about the new S905X2 ( u211) & S905Y2 ?
                  What News you mean ;-)
                  As far we know Guest is Working on a TWRP Build for that Devices.
                  Neomode
                    Originally posted by Jaro7 View Post
                    Backup Failed
                    Can you fix it?
                    (pid 4049)
                    [BACKUP STARTED]
                    Is there anybody for whom the TWRP compression works on a Mecool KIII Pro with Android 7?
                      Neomode
                      Hmm ....
                      I didn't know it !
                      That's good news !
                      Waiting for it/them...!
                      Regards
                        Okay, here's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference hardware: twrp.u211-3.2.3-0.img
                        It's built with the twrp-8.1 minimum OMNI branch and is using a prebuilt GT1 Mini kernel. I'll be creating a twrp-8.1 branch in the Amlogic repository for this along with updates for the q201 and p212 reference hardware.
                        • Guest's Avatar
                          Guest commented
                          Editing a comment
                          UPDATE: The GitHub repository has been updated. There's a screen blanking issue on twrp-8.1 that I'm seeing on q201 (S912) and p212 (S905X), but it doesn't seem to be affecting u211 (S905X2). Trying to track down a fix with Amlogic. For now, you can work around the problem by simply unplugging and reconnecting the HDMI cable.
                        [QUOTE=Magendanz;n755206]Okay, here's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference hardware: twrp.u211-3.2.3-0.img
                        It's built with the [URL="https://github.com/minimal-manifest-twrp.
                        Chad, hate to chase you down here, and break your chain of thought. But....
                        Could you, would you educate me by pm, or us over at:
                        rockchip-3399-magicsee n6... Regarding lack of or how to get a twrp built for said device?
                        It comes with a su rooted admin., and Many bugs. Imagine that!?
                        Anyway clarifying what is the soc fault that No builds can be found... So it Must be serious, or sinister? But so very hard to believe.
                        Trying my first but long coveted 3399, I've now got cold feet. Fear of the inevitable "Brick" is taking hold, without this awesome lifeline. It, pretty much, has saved me uncounted times.
                        I'm sure you know that, Make me feel like I am about to be in the wilderness without a paddle, er.. whatever.
                        Whatta ya say? Spread a little smarts our way?
                        • Guest's Avatar
                          Guest commented
                          Editing a comment
                          There's a separate thread to read for TWRP for Rockchip devices. I simply haven't done much custom ROM development on Rockchip, and I've never had a 3399 device. It should be relatively straightforward to build one, though, and I posted the RK3328 device tree source.
                        You should also take a look here:
                        Some good information about RK3399.
                        Neomode
                          Neomode
                          Thank you Neo, and of course, Super Mag.
                          Definitely good stuff linked there...
                          I sometimes wonder why a company like Magicsee, and so many others, doesn't fire their dev ​​​​​​ team
                          ... And contract with a brain trust like freaktab seniors. The upside benefits would seem unlimited.
                          Logic and common sense supply gap, methinks?
                          Neo ... Are you admin, here at FT?
                          I'm plagued with page navigation ALWAYS Defaulting to open comments section.
                          I'd like to pm with someone within for a solution.
                          Ongoing for months now.
                          Thanks for the data link, already interesting!
